How to develop PC-DMIS in Python?
  • How to develop PC-DMIS in Python?
    Tks!
    1) purchase pc dmis
    2) purchase python
    3) feed discs and instruction manuals to python
    4) in about 24 hours it should push out some results
    • InspectorJester
      InspectorJester commented
      That's what I did! It worked!
    3) feed discs and instruction manuals to python----->To whom is the CD-ROM and the instructions to be given?
    • dph51
      dph51 commented
      John Cleese
    • arttk
      arttk commented
      dph51: What?????
    • sealevel
      sealevel commented
      dph51..... you want PC-DMIS Forum 12A, Just along the corridor.............
    PC-DMIS allows external programs to access, but through the COMM interface. You'd have to create a comm interface and launch a dispatch command etc. etc.
      Could you use Python for a front-end GUI with a VB engine driving the demon?
        Yes. I've seen it done with Java in a similar way.
          Here's a snippet of some of the simple functions I've written in Python with pywin32 for issues I've run across.
          I'm still pretty new to COM automation, so there's probably a lot that could be done better.
          I've messed around in Ruby a bit as well.
          import win32com.client as w32
          import re
          import math
          dmisapp = w32.Dispatch('PCDLRN.Application')
          dmispart = dmisapp.ActivePartProgram
          dmiscommands = dmispart.Commands
          def delmvpts(dmiscommands):
            type_list =  [150, 162, 60, 61] # 150:MovePoint, 162:MoveAll 60:Tipchng, 61:Loadprobe
            for cmd in dmiscommands:
              if cmd.Type in type_list:
                print(cmd.ID, " deleted.")
                cmd.Remove()
          def addxtheo(dmiscommands):
              if cmd.IsFeature:
                initx = cmd.GetText(7,0)
                cmd.PutText(str(float(initx) - 80), 7,0) # Shifts theo X by 80mm
                cmd.PutText(str(float(initx) - 80), 22,0)
          def namefeexr(dmiscommands):
              if cmd.IsFeature:
                if "A167" in cmd.ID:
                  cmd.ID = cmd.ID.replace("(.*)L", "\1R") # Changes feature name from left to right.
          # delmvpts(dmiscommands)
          # addxtheo(dmiscommands)
          • arttk
            arttk commented
            Great! Thanks!
          • InspectorJester
            Now if only I could implement this on a Raspberry Pi...
