End of Dimension....
  • End of Dimension....
    Has anyone had a program lose the line that says "End of dimension" after True position and location dimensions?
    Halfway through the reporting section of a program I have lost these "end of dimension" lines.
    The problem is the dimension stays open so if i hit enter at the end of the dimension it just keeps adding more axis. I can not insert dimension's, comments,alignments,variables...nothing! in this area of the program "No legal insertion point below" is the message i get. This goes on for the last 3000 lines of the program.
    Currently I am re-dimensioning this section(Which will take a day or two...aargh!) of the program & curious to know why or how this happened.
    Any comments?
    I just realized i posted this in the code forum.....Sorry about that..
    Last edited by spazus_maximus; 03-05-2007, 04:29 PM. Reason: Posted in wrong forum!
    Spaz,
    I know this is an old post, but if you didn't get it by now there's a vb file on the wilcox site that you can dowload and run and it automaticly puts the end of dimension back in. You have to register to get access to it.
    If A Pretty Poster And A Cute Saying Are All It Takes To Motivate You,
    You Probably Have A Very Easy Job. The Kind Robots Will Be Doing Soon.
      Sorry, forgot to post the link. Register here for access to the repository.
        There ya go spaz....someone answered your question & i believe you have a new bestest friend or bunk buddy
          Sorry to bump an old thread but I have this issue in CAD++ 2011 MR1 and the above link is dead. Does anyone know where I can currently find the file (or if it will even work on 2011)? I tried searching the PCDMIS site but can't find snot.
          Downtime: The short span between the job you just finished and the job you are putting off doing. - Glenn Downey
            Here is the Link for the old Wilcox script repository
            http://www.wilcoxassoc.com/perl/secu...mensionend.zip
              Attribute VB_Name = "Insert Position End or Location End"
              Option Explicit
              ''' This script has been created by Wade Burton To replace the End command of
              ''' location Or True position dimensions when they somehow are missing.  We
              ''' Do Not know how they Get removed, And is a problem when they are missing
              ''' because Then you can Not properly mark/unmark, delete, copy/paste these
              ''' dimensions.  This script searches through the part program And determines
              ''' which dimensions are missing the End commands And inserts the End In
              ''' the appropriate position.  Message boxes will display which dimensions
              ''' have been fixed.
              Sub main()
              Dim app As Object
              Dim part As Object
              Dim cmds As Object
              Dim cmd As Object
              Dim dimensionCmd As Object
              Dim strMessage As String
              Dim strDimensionID As String
              Dim blnDimensionHasEnd As Boolean
              Dim intNumMissingLocationEnds  As Integer
              Dim intNumMissingPositionEnds  As Integer
              Dim cmdToBeInsertedAfter As Object
              Dim intCmdType As Integer
              Dim blnCmdIsMarked As Boolean
              Set app = CreateObject("PCDLRN.Application")
              Set part = app.ActivePartProgram
              Set cmds = part.Commands
              'Sub main()
              intNumMissingLocationEnds  = 0
              intNumMissingPositionEnds  = 0
              For Each cmd In cmds
                  Set intCmdType = cmd.Type
                  blnCmdIsMarked  = cmd.Marked
                  If intCmdType = DIMENSION_START_LOCATION Or intCmdType = DIMENSION_TRUE_START_POSITION Then
                     blnDimensionHasEnd = False
                     Set dimensionCmd = cmd
                     Set  cmdToBeInsertedAfter  = dimensionCmd
                     strDimensionID = "Dimension ID=" & dimensionCmd.ID
                     dimensionCmd = dimensionCmd.Next
                     'This dimensionCmd should be the command that follows the start of the dimension.  It should be an x,y,z,pa, etc. Or an End command.
                     'So we search through the Next group of commands For the End command.  If we hit another start dimension Or a command
                     'that is Not part of the current dimension we've gone too far.  If no End exists Then Set the Boolean variable so later we
                     'can either Put up a message Or insert the End.     In the numbers of axes, the End comes after the start And the straightness is the last axis In the order.
                     Do While (dimensionCmd.Type >= DIMENSION_END_LOCATION And dimensionCmd.Type <= DIMENSION_STRAIGHTNESS_LOCATION)
                       If (dimensionCmd.Type = DIMENSION_END_LOCATION) Then
                         blnDimensionHasEnd = True
                       Else
                         cmds.InsertionPointAfter cmdToBeInsertedAfter
                       End If
                       dimensionCmd.Next
                     Loop
                     Do While (dimensionCmd.Type >= DIMENSION_TRUE_END_POSITION And dimensionCmd.Type <= DIMENSION_TRUE_STRAIGHTNESS_LOCATION)
                       If (dimensionCmd.Type = DIMENSION_TRUE_END_POSITION) Then
                       Else
                       End If
                       dimensionCmd.Next
                     Loop
                     'If we made it To the End of the dimension And didn't find an End, Then insert a new End
                     If blnDimensionHasEnd = False And intCmdType = DIMENSION_START_LOCATION Then
                       intNumMissingLocationEnds = intNumMissingLocationEnds + 1
                       strMessage = strDimensionID + " - Location dimension #" + Format(intNumMissingLocationEnds, "")
                       MsgBox (strMessage)
                       Set cmd = cmds.Add(DIMENSION_END_LOCATION, True)
                       If blnCmdIsMarked = True Then
                         cmd.Mark
                       End If
                     ElseIf blnDimensionHasEnd = False And intCmdType = DIMENSION_TRUE_START_POSITION Then
                       intNumMissingPositionEnds = intNumMissingPositionEnds + 1
                       strMessage = strDimensionID + " - Position dimension #" + Format(intNumMissingPositionEnds, "")
                       MsgBox (strMessage)
                       Set cmd = cmds.Add(DIMENSION_TRUE_END_POSITION, True)
                         cmd.Mark
                       End If
                     End If
                  End If
              Next cmd
              strMessage = intNumMissingLocationEnds & " Location Dimensions with missing End Commands fixed."
              MsgBox (strMessage)
              strMessage = intNumMissingPositionEnds & " Position Dimensions with missing End Commands fixed."
              MsgBox (strMessage)
              End Sub
              Here is the InsertDimensionEnd.bas code for the Basic Script Editor.
                Forum
                Development and Technical Previews
                PC-DMIS 2012 Technical Preview - This forum is now closed to new posts
                "corrupt program" moving dimension summary mode
                This will give you more info on this issue.
                http://www.pcdmisforum.com/showthrea...n-summary-mode
                  This just happened to me earlier today. I don't know if this is a coincidence or bad voodoo from of digging up this old thread.
                    Baaaad voodoo! When this happened the last time, I had only four locations that lost the End of Dim line. My fix was to delete them and just re-dimension. I wasn't able to access the above link but I'll hang on to the script in case it happens again with more than a few features.
