Print command not working
  • Print command not working
    Hi all......
    today I tried the print command for the first time, everything seems like correct but still its not woring.
    It is not getting saved in the location which i defined, instead of that its storing some other location.
    i want to save my reports in "C:\Reports\customer_name\Part_number\Lot_numb er" in the format of Part_number__ddmmyyyy__variant.pdf
    if the operator enters new lot number means pc-dmis should create a new folder by itself.
    here my code is , if there is any mistake pls correct me.
    thanks in advance.
    "header section"
    C1         =COMMENT/INPUT,YES,FULL SCREEN=NO,
                ENTER PART NUMBER
    C2         =COMMENT/INPUT,YES,FULL SCREEN=NO,
                ENTER JOB ROUTER NUMBER
    C3         =COMMENT/INPUT,YES,FULL SCREEN=NO,
                ENTER CUSTOMER NAME
                ASSIGN/PART_NUM=C1.INPUT
                ASSIGN/LOT_NUM=C2.INPUT
            ASSIGN/CUST_NAME=C3.INPUT
                ASSIGN/DATE=GETPROGRAMINFO("DATE")
                ASSIGN/VARIANT=GETPROGRAMINFO("STATSCOUNT")
    "at the end of the prograrm"
                 ASSIGN/FILE_NAME=PART_NUM+"__"+DATE+"__"+VARIANT+".PDF"
                ASSIGN/REPORT_PATH="C:\REPORT\CUST_NAME\PART_NUM\LOT_NUM\\"
                ASSIGN/REPORT=REPORT_PATH+FILE_NAME
                PRINT/REPORT,EXEC MODE=END,$
                  TO_FILE=ON,OVERWRITE=REPORT,$
                  TO_PRINTER=OFF,$
                  TO_DMIS_REPORT=OFF,FILE_OPTION=OVERWRITE,FILENAME="",$
                  REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$
    Try this.....
    "header section"
    ENTER PART NUMBER
    ENTER CUSTOMER NAME
    "at the end of the
    ASSIGN/FILE_NAME=PART_NUM+ "__" +DATE+ "__" +VARIANT +".PDF"
    ASSIGN/REPORT_PATH="C:\\REPORT\\" +CUST_NAME + "\\" + PART_NUM +"\\" + LOT_NUM +"\\"
    TO_PRINTER=OFF,$
    [/QUOTE]
      Print commands are funny, on my end, if the print under the file dropdown is not turned on and set to a bogus dummy output, the print command in the edit window wont function. May not apply to you cuz it actually outputting it not the issue but location.
      When in doubt of variable values hover over them and you can see variable output or use the ol' poor mans debugger trick, Operator comments.
      PcDmis 2015.1 SP10 CAD++
      Global 7-10-7 DC800S
        i changed my code as dph51 said now the command is OK, but sad thing is still the report was storing in program location
          What is the mistake i'm doing ? still, my Reports are getting stored in Program Location
            ASSIGN/FILE_NAME=PART_NUM+"__"+DATE+"__"+TIME+"__"+VARIANT+".PDF"
                          ASSIGN/REPORT_PATH="C:\\REPORT\\CUST_NAME\\"+PART_NUM+"\\"+LOT_NUM+"\\"
                        TO_PRINTER=OFF,$
            Maybe PC-DMIS gets confused with your variable name "REPORT", as that's a built-in name?
              AndersI , Still it continues. after Changing the variable name as well as folder name.
                ASSIGN/FILENAME=PART_NUM+"__"+DATE+"__"+TIME+"__"+VARIANT+".PDF"
                          ASSIGN/FILESTORE="C:\\CUST_NAME\\FQR\\"+PART_NUM+"\\"+LOT_NUM+"\\"
                          ASSIGN/VAL_FILE=FILESTORE+FILENAME
                            TO_FILE=ON,OVERWRITE=VAL_FILE,$
                            TO_PRINTER=OFF,$
                Dumb question - does the folder "C:\\CUST_NAME\\FQR"+PART_NUM+""+LOT_NUM+"" exist? The print command can only create files, not folders.
                Edit: The forum eats backslashes, but I wrote it exactly as your post displayed it.
                Edit 2: Every time I edit some more backslashes are eaten!
                  AndersI Have some of mine:
                  PC-DMIS CAD++ 2o19 R1 SP3
                    Maybe this is the problem that needs to be changed. Your post showed
                    ASSIGN/REOPRT_PATH="C:\\REPORT\\CUST_NAME...........etc
                    ASSIGN/REPORT_PATH="C:\\REPORT\\+ CUST_NAME +"\\" +PART_NUM+"\\"+LOT_NUM+"\\"
                    TO_PRINTER=OFF,$
                    • vpt.se
                      vpt.se commented
                      assign/report_path="c:\\report\\"+ cust_name +"\\" +part_num+"\\"+lot_num+"\\"
                    Try running your PC-DMIS application as Administrator.
