I'm having trouble with measuring a cylinder cut by 2 non-perpendicular planes. Can anyone tell me the mathematical fundamentals of the measurement? How can they determine thw radius with only 6 points? Thank you!
Cylinder measuring
Think about it differently
I don't know the math for solving a cylinder with 6 points, but what is the problem you are trying to solve? Is it that you cannot get enough hits on it? That the hits are not normal to the surface? That the cylinder does not repeat? That you don't know the nominal data? DOes it not learn well?
Please elaborate on the fundamental problem, and perhaps we can find a solution. . .
by UnderspecMeasuring off CAD model. When creating the cylinder it looks correct in the graphics window (along Z). But when it's measured, the **** thing flips vectors...
07-12-2007, 10:20 AM -
by JStewartGood morning!
I'm trying to create a cylinder between two existing cylinders and comng up empty. How is this done? Do I need to extract...-
11-19-2010, 10:48 AM -
by pernillaHi.
I need to measure the diameter and runout of a cylinder (as marked in picture).
The programmer previous to me solved this by measuring...-
03-14-2019, 03:54 AM -
by hwillyWe have a job on now, it's a housing with an internal cylinder as the only datum on the drawing. I need to check the perpendicularity of all the machined...
04-14-2010, 06:30 AM -
by 12345I want to construct a line, parallel to the C/L of a cylinder
on the OD of the cylinder.
that is the I/O a plane and the cylinder
04-14-2009, 12:45 PM -
