Operators Bypassing Filling Out the Form: Flow Control
  • Operators Bypassing Filling Out the Form: Flow Control
    Happy Saturday!
    At the beginning of each program, I have a Form that operators need to fill out. Unfortunately, we have operators that like to just click the continue button on the execution box, which bypasses the form and the program continues. This will not cause the program to crash, but along with other people, I like to see what job# the part was run, who ran it, and for what reason. (Each tracefield is coded into a customized header) So I have had to create a flow control that will not allow operators to bypass the form. They will need to completely fill it out to continue running the program. Hopefully this will help someone who may be in the same situation.
    REFILL     =LABEL/
                ASSIGN/STR_INSPECT=""
                ASSIGN/STR_USER=""
                ASSIGN/STR_DESC=""
    CS1        =FORM/FILENAME= C:\USERS\CMM\DOCUMENTS\CMM FILES\FORMS\INSPECTIONFORM.FORM
                PARAM/TXTINSPECT.TEXT=STR_INSPECT
                PARAM/TXTUSER.TEXT=STR_USER
                PARAM/TXTDESCRIPTION.TEXT=STR_DESC
                PARAM/=
                ENDFORM/
                ASSIGN/FORM1=STR_USER
                ASSIGN/FORM2=STR_INSPECT
                ASSIGN/FORM3=STR_DESC
                IF/FORM1=="" OR FORM2=="" OR FORM3==""
                  Please completely fill out the form in the upper left corner.
                GOTO/REFILL
                END_IF/
                TRACEFIELD/NO_DISPLAY,LIMIT=15 ; TECH / OPERATOR : FORM1
                TRACEFIELD/NO_DISPLAY,LIMIT=20 ; COMMENTS : FORM2
                TRACEFIELD/NO_DISPLAY,LIMIT=15 ; JOB / PART# : FORM3
    I use VB to hide the execution window, and only enable the 'Continue' button on the form when they've filled in the info required, I then re-show the execution window.
    • mb0258
      mb0258 commented
      Hello NinjaBadger, is it possible to share code VB or point me where to find how to do ?: open form, hide execution window, continue program only with OK button, I know how to handle form variable, and how to use condition to check if variable inputs are correct, but I cannot succes with open form fullscrean.
    I have the continue button on the form set up to not work unless the form is completely filled out, but am not sure how to hide the execution box during that form filling process. So this is my work around.
      Pseudo-code:
      Assign COUNTER=0
      Label RETRY
      Assign COUNTER=COUNTER+1
      If COUNTER>3 then operator comment "Go see supervisor"
      and Goto end of program
      End If
      declare variables, assign each to be value 0
      Call form
      If important variable == 0 then GOTO label Retry
        Originally posted by Josh Carpenter View Post
        Pseudo-code:
        Assign COUNTER=0
        Label RETRY
        End If
        Call form
        "Go See Supervisor"...Nice! There are times where I want to insert a "Slap yourself really hard" if they keep screwing up when fixturing a part or typing in data, but I am sure that would be frowned upon in our organization.
