Counting OUTTOL in a program
  • Counting OUTTOL in a program
    NOTE: There's a much better solution here: http://www.pcdmisforum.com/showthrea...l=1#post401750
    Forget this...
    This is my script for counting the number of OUTTOL in a program, for use on older versions of PC-DMIS that don't have GETPROGRAMINFO(...).
    (Sorry for Swedish, but I think you can understand it)
    ' Count all dimensions out of tolerance
    ' Set the indicated PCDMIS variable to the number
    ' Usage:
    '            TILLDELA/OT=0
    'CS1        =SKRIPT/FILNAMN= C:\DOCUMENTS AND SETTINGS\ALL USERS\DOKUMENT\WAI\PC-DMIS\2010 MR2\COUNTOUTOFTOL.BAS
    '            FUNKTION/CountOutOfTol,VISA=JA,ARG1="OT",,
    '            BÖRJA_SKRIPT/
    '            SLUTA_SKRIPT/
    '            KOMMENTAR/OPERATÖR,NEJ,HELSKÄRM=NEJ,FORTSÄTT AUTOMATISKT=NEJ,
    '            Antal utvärderingar utom tolerans
    '            OT
    Sub CountOutOfTol(OutTolVar As String)
    Dim App As Object
    Set App = CreateObject("PCDLRN.Application")
    Dim Part As Object
    Set Part = App.ActivePartProgram
    Dim Cmds As Object
    Set Cmds = Part.Commands
    Dim Cmd As Object
    Dim DCmd As Object
    Dim FCFOT As String
    Dim I As Integer
    Dim OutTolValue As Object
    Set OutTolValue = Part.GetVariableValue(OutTolVar)
    If Not OutTolValue is Nothing Then
      OutTolValue.LongValue = 0
      For Each Cmd In Cmds
        If Cmd.IsDimension Then
          If Cmd.Type <> DIMENSION_START_LOCATION And _
             Cmd.Type <> DIMENSION_END_LOCATION And _
             Cmd.Type <> DIMENSION_TRUE_START_POSITION And _
             Cmd.Type <> DIMENSION_TRUE_END_POSITION Then
            Set DCmd = Cmd.DimensionCommand
            if (DCmd.OutTol <> 0) then
              OutTolValue.LongValue = OutTolValue.LongValue + 1
            End If
          End If
        ElseIf Cmd.Type = 184 Then ' FCF
          I = 1
          FCFOT = Cmd.GetText (LINE2_OUTTOL, I)
          While (Not OutOfTol) And (FCFOT <> "")
            If Val(FCFOT) <> 0 Then
            End If
            I = I + 1
          Wend
        End If
      Next Cmd
        Part.SetVariableValue OutTolVar, OutTolValue
      End If
    Else
       MsgBox "Variabeln " + OutTolVar + " saknas i PCDMIS-programmet!"
    End If
    End Sub
    Sub Main
    End Sub
    AndersI - That is very close to my VB script for getting the Deviation values for all features to dump into a CSV file or to SQL. Didn't know the Name to go after or the value of 184... Nice !!!
      I hope it works for you! Btw. the value 184 should really be FEATURE_CONTROL_FRAME instead. You can find all these values (and names) by exploring the Type Library (pcdlrn.tlb) that is imported in Excel (or any other development tool) and applying a bit of imagination...
        What is ---> FUNKTION/CountOutOfTol,VISA=JA,ARG1="OT",,
        Cannot get Script to read value(OutTolVAR) from PC-Dmis though. Did try changing to OUTTOLVAR and OT as PC-Dmis would ASSIGN it.
        Tried changing settings in the beginning to match what I have benn using. Also swapped 184 for (FEATURE_CONTROL_FRAME). Any ideas ?
          This works for me in 2014.1 - can't say if older versions are doing something differently...
                      ASSIGN/OT=0
          CS1        =SCRIPT/FILENAME= C:\USERS\PUBLIC\DOCUMENTS\WAI\PC-DMIS\2014.1\COUNTOUTTOL.BAS
                      FUNCTION/CountOutOfTol,SHOW=YES,ARG1="OT",,
                      STARTSCRIPT/
                      ENDSCRIPT/
                      OT
            I'm trying to do this as an executable (.exe) file instead of a .bas file. Did try it as a .bas file a couple of times, but value is not passing. Also, cannot insert ENDSCRIPT/ Command into PC-DMIS. Keeps going to ENDGROUP or ENDSUB.
              I think if you set PC-DMIS to show header/footer, the number of out of tolerance features will be at the bottom (in the footer).
                Need to keep PC-DMIS from changing the "WAIT" to "NO_WAIT" in the EXTERNALCOMMAND line. It runs fine for a while then flipst. Of course, I have to re-load the programs again. I think I saw something about locking a command line so that PC-DMIS can't change the settings in it. You're suppose to put something in front of it ??? Hate when I can't remember... LOL !!!
                  Can you add a compressed file COUNTOUTOFTOL.BAS? Thanks!!
                  I also ENDSCRITP / do not add up.
                    For those interested, my script missed (at least) outtols in the second segment of composite FCF:s. Edited version:
                    ' Usage:
                    '            TILLDELA/OT=0
                    '            BÖRJA_SKRIPT/
                    '            SLUTA_SKRIPT/
                    '            OT
                    Dim App As Object
                    Dim Part As Object
                    Dim Cmds As Object
                    Dim Cmd As Object
                    Dim DCmd As Object
                    Dim FCFOT As String
                    Dim I As Integer
                            End If
                          End If
                          I = 1
                            End If
                            I = I + 1
                          Wend
                          I = 1
                          FCFOT = Cmd.GetText (LINE3_OUTTOL, I)
                            End If
                            I = I + 1
                          Wend
                        End If
                      Next Cmd
                      End If
                    Else
                    End If
                    End Sub
                    Sub Main
                    End Sub
