Set A Variable in PC-DMIS with a textbox in VB.Net
  • Set A Variable in PC-DMIS with a textbox in VB.Net
    Hi guys,
    I have taken on the task of automating our CMM operations, and so far I have been able to push through some of my issues but I am stumped on this one. All I want to do is have the VB program output whatever is written in a textbox into a variable on PC-Dmis.
    Thanks for the help.
    Matt
    Global Advantage 5 7 5
    PC-DMIS v2014SP1
    You need to connect to PC-DMIS through COM/OLE (in your VB app) and then fetch the value using GetVariableValue().
    I believe the necessary sources/steps for this is available in this section.
    PC-DMIS CAD++ 2o19 R1 SP2
      Thanks vpt
      So I keep getting a Type Mismatch error. Here is the vb code
      Private Sub VarSet()
              Dim PCDPart As Object
              PCDPart = PCDApp.ActivePartProgram
              Dim JOBNO As Object
              JOBNO = PCDPart.GetVariableValue("JOBNO")
              Dim I As Object
              If Not JOBNO Is Nothing Then
                  JOBNO.LongValue = TextBox3.Text
                  PCDPart.SetVariableValue("JOBNO", JOBNO)
              Else
                  MsgBox("Could Not Find JOBNO Variable")
              End If
              endForm()
          End Sub
      And here is what I am trying to set in PC-DMIS
      ASSIGN/JOBNO=0
      Thanks for the help guys.
      PC-DMIS v2014SP1
        .LongValue is expecting a floating point number like 3.1415926536, but you are trying to transfer text. You should use .StringValue instead.
        And I would suggest ASSIGN/JOBNO="" in the PP, so that the type is correct (I don't think that is necessary, but it helps you remembering what's expected).
          I changed .LongValue to .StringValue and now the program runs through, but the variable doesn't change value. I also tried it with no number in the assignment, and that didn't work.
          PC-DMIS v2014SP1
            This is a snippet of code the way I do it in VB6 -
            For Each Cmd In Cmds
            If Cmd.TypeDescription = "Assignment" And Cmd.GetText(DEST_EXPR, 0) = "JOBNO" Then
            bln = Cmd.PutText("1234", SRC_EXPR, 0)
            End If
            Next Cmd
              ^Don's method doesn't require a program execution where setvariablevalue requires the execution of the program to read and modify variable values.
                Is Cmds Dim'd as Cmds As PCDLRN.Commands or something else? If that is correct Im getting an "Expression is of type 'PCDLRN.Commands', which is not a collection type" error.
                Here is the whole program:
                Imports PCDLRN
                Imports System
                Imports System.IO
                Imports System.Text
                Imports Microsoft.Office.Interop.Excel
                Imports System.Threading
                Public Class Form1
                    Dim PCDApp As PCDLRN.Application
                    Dim pcdpartprograms As PCDLRN.PartPrograms
                    Dim pcdActivePart As PCDLRN.PartProgram
                    Dim WithEvents AppEvents As PCDLRN.ApplicationObjectEvents
                    Dim Cmds As PCDLRN.Commands
                    Dim Cmd As PCDLRN.Command
                        'Loads PC-DMIS and Opens the Part Program based on inputs
                    Public Sub PCDLoad()
                        Dim fname As String
                        fname = "\\hemfile1\share\PartNumber\" & TextBox1.Text & "\Quality\CMM\Program Files\" & TextBox1.Text & " - " & TextBox2.Text & ".PRG"
                        PCDApp = CreateObject("PCDLRN.Application")
                        PCDApp.WaitUntilReady(60)
                        Threading.Thread.Sleep(2000)
                        pcdpartprograms = PCDApp.PartPrograms
                        PCDApp.Visible = True
                        PCDApp.SetActive()
                        PCDApp.Maximize()
                        pcdpartprograms.CloseAll()
                        pcdpartprograms.Open(fname, "Machine1")
                        VarSet()
                    End Sub
                    Public Sub VarSet()
                        pcdActivePart = PCDApp.ActivePartProgram
                        Cmds = pcdActivePart.Commands
                                retval = Cmd.PutText("1234", SRC_EXPR, 0)
                            End If
                        Next Cmd
                        endForm()
                    End Sub
                    'Loads the Set-up Sheet if one is available, Then Loads PCDLoad Sub
                    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
                        Dim path As String = "\\hemfile1\share\PartNumber\" & TextBox1.Text & "\Quality\CMM\Program Files\" & TextBox1.Text & ".xlsx"
                        If SetupSheet = True Then
                            If System.IO.File.Exists(path) Then
                                Process.Start("excel.exe", String.Format("/r {0}{1}{0}", """", path))
                            Else
                                MessageBox.Show("No Set-Up Sheet Available")
                            End If
                        End If
                        PCDLoad()
                    End Sub
                    Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
                        Me.Close()
                    End Sub
                    Private Sub endForm()
                        Me.Close()
                    End Sub
                    'Set-Up Sheet Code
                    Private SetupSheet As Boolean
                    Private Sub CheckBox1_CheckedChanged(sender As Object, e As EventArgs) Handles CheckBox1.CheckedChanged
                        If CheckBox1.Checked = True Then
                            SetupSheet = True
                        Else
                            SetupSheet = False
                        End If
                    End Sub
                End Class
                The red bit is what is hanging things up.
                PC-DMIS v2014SP1
                  Imports PCDLRN
                  Imports System
                  Imports System.IO
                  Imports System.Text
                  Public Class Form1
                          Dim fname As String
                          PCDApp.SetActive()
                          PCDApp.Maximize()
                          VarSet()
                      End Sub
                      Public Sub VarSet()
                          Set Cmd = Cmds.Item(cnt)
                               If Cmd.Type = "Assignment" And Cmd.GetText(DEST_EXPR, 0) = "JOBNO" Then
                              End If
                          Next Cmd
                          endForm()
                      End Sub
                              Else
                              End If
                          End If
                          PCDLoad()
                      End Sub
                          Me.Close()
                      End Sub
                          Me.Close()
                      End Sub
                      'Set-Up Sheet Code
                              SetupSheet = True
                          Else
                              SetupSheet = False
                          End If
                      End Sub
                  End Class
                  See bolded part
                    you may have to call out an object to set the cmd.GetText to and enclose everything in parenthesis.
                    You can also try to call out .type to the equivalent string name.
                    varname = "JOBNO"
                    If ((Cmd.Type = 195) And (varname = Cmd.GetText(DEST_EXPR, 0))) Then
                                End If
                            Next Cmd
                      Thanks for the help Don and Rploughe, I think the problem lies with VB.Net and/or the 2014 PCDLRN Object Library.
                      It still gives me that same error on the For Each Cmd in Cmds
                      PC-DMIS v2014SP1
                         Public Sub VarSet()
                                Dim PCDPart,Cmds,Cmd As Object
                                Cmds = PCDPart.Commands
                                    End If
                                Next Cmd
                                endForm()
                            End Sub
                        See what I bolded. I think it might of been overlooked.
                          So now the DEST_EXPR, retval, and SRC_EXPR commands are saying they are not declared.
                          PC-DMIS v2014SP1
                            I do know that VB.Net has an issue with collections, they are pretty much not recognized. You would need to use something more like
                            For each Cmd in Cmds.Count
                              You can always do (PC-DMIS BASIC, might differ slightly from VB.NET)
                                For I = 1 to Cmds.Count
                                  Set Cmd = Cmds(I)
                                  <do something with Cmd>
                                Next I
                              or
                                Cmd = Cmds[1]
                                while ??some expression testing for not null which I don't remember how it should look??
                                  <do something with cmd>
                                  Cmd = Cmd.Next
                                end while
