pass variable directly to script
  • pass variable directly to script
    Hi All,
    I hope this makes sense.
    Is there a way to pass a variable to a basic script when it is called from a PCDMIS program?
    I see there is the ability to provide Destination Expressions in the PCDMIS program, can I access these from the script?
    I know I can access assignment values but I'm looking for something to be passed when the script was called and could be different if I called the script multiple times.
    Thanks
    JVWhy CAD++ 2013 MR1 SP5 B&S Global Advantage.
    Optimism is the leading cause of disappointment.
    You can use a script command in the edit window like this -
    CS2 =SCRIPT/FILENAME= C:\USERS\PUBLIC\DOCUMENTS\WAI\PC-DMIS\2013 MR1\SCRIPT1.BAS
    FUNCTION/Main,SHOW=YES,ARG1="Don",,
    STARTSCRIPT/
    ENDSCRIPT/
    and then a script like this -
    Sub main(strID As String)
    MsgBox "Hello " + strID
    End Sub
      PERFECT, Exactly what I needed.
