Someone was checking thickness of a part with PCDMIS using distance. The part program had over 150 dimensions. Wanting to know the minimum distance he asked me if it could be coded instead of sifting through a 150+ dimension report. Knowing that distance is the only type of dimension in the program I wrote him this .bas
My question is how do I check what type of dimension I am looking at? If there are any other dimensions in the program this will not ignore them and they will be used in the calculation of finding the minimum. I want to be able to go through and only use distance data. For now this works fine for him but I think it would be nice to be able to be specific as to the exact type of dimension. Right now because he has 3.2063 (does not support SetVariableValue) he reads it in from the text file with PCDMIS to set a variable. The variable has to be reported in a comment of some kind (either report or operator). If it is assigned to a generic feature and dimensioned that dimension gets evaluated by the .bas and returns 0 because it has not been set at the time the script runs. Does anyone know how to evaluate dimensions to get their specific type (ie location, true position, concentricity, flatness etc)?
Craig
Sub Main() Dim pcdmis As Object Dim Part As Object Dim Cmds As Object Dim Cmd As Object Dim DimCmd As Object Set pcdmis = CreateObject("pcdlrn.application") Set Part = pcdmis.ActivePartProgram Set Cmds = Part.Commands Dim dblMeasurment As Double Dim dblMinimum As Double Dim intCounter As Integer intCounter = 0 For Each Cmd In Cmds If Cmd.IsDimension Then Set DimCmd = Cmd.DimensionCommand dblMeasurment = DimCmd.Measured If intCounter = 0 Or dblMeasurment < dblMinimum Then dblMinimum = dblMeasurment End If intCounter = intCounter + 1 End If Next Cmd Dim strTheFile As String strTheFile = "C:\Minimum.txt" Open strTheFile For Output As #1 Write #1, dblMinimum Close #1 End Sub
Craig
