I have a program that measures 700+ points on an airfoil surface. I'm looking for an easy way to export the nominal and measured values into a txt file as feature name, X nom, Y nom, Z nom, X meas, Y meas, Z meas, X dev, Y dev, Z dev. I'm currently programming to put the values into an array and write to a file after every point measurement.
It would obviously be easier to have a script that would look for all feature names in a certain format, i.e. PNT_1, PNT_2, etc, write the data to a file, then look for the next feature. I wasn't planning on dimensioning any of the points but will if I have to. If someone can point me in the right direction I would greatly appreciate it.
