So I am use to BladeRunner and it has the option of having a badge ID and Serial number input. Any way I can do the same with Inspect without it using it as an input within the program?
Badge ID and serial number input
With the new Inspect Automate option, you can create Trace Fields in Inspect, which are then passed into the routine as variables.
You would need to put your routine into a playlist, and from playlist, you can configure the trace parameters.
If any trace parameter is a user entered field, then the operator would need to enter it at the start of the measurement.
This may fulfill what you are looking for.
by mwheeler
I have parts that have individual serial numbers and I want the serial number to show up on the top of the report. Can this be done? I tried...
04-03-2007, 01:05 PM -
by Ben1989Hi all,
Just looking for a way of making operator input more obvious than it already is in our programs.
In the program we ask...-
08-22-2016, 07:27 AM -
by acgarciaGood Evening All:
I thought I throw this out there before I shut it down for the night. What report saving methods do you all use when saving...-
09-15-2017, 12:45 AM -
by sfieldHow can I update the serial number field in the report header with an input comment? I want to the input comment to pop up and ask the operator for the...
02-12-2016, 10:13 AM -
by acgarciaI save pdf reports as my parts serial number directly to my network. Operator scan a barcode in an input comment and I use variables for reporting and...
Channel: Tips & Tricks
01-29-2020, 03:42 PM -
