I Would Like To Have Max & Min Included When I Use And Export The Spreadsheet Report. Can This Be Added And Where Would I Go To Do This If I Can?
Max/min In Data Spreadsheet Report?
Originally posted by SABarber View PostThis is not possible. The spreadsheet report displays the values (Nom/Up/Low/Measured) of each transaction. Where would the max/min go?sigpic
PCDMIS 4.1, 3.5mr2,
Re: Max/Min
You can get Datapage to report the Max/Min, but, you must make the Max and the Min basically their own seperate entity. If you assign a variable to the max and to the min, and then create a generic feature using those 2 variables, you can report the max and the min as a dimension unto itself. There may be an easier way, but this is what I have done in the past.sigpic
Spreadsheets basically reprot each seperate run for each seperate variable. The best way to do this would be to turn on Upper Deviation and Lower Deviation in a Statistical Report.sigpic
If A Pretty Poster And A Cute Saying Are All It Takes To Motivate You,
You Probably Have A Very Easy Job. The Kind Robots Will Be Doing Soon.
I know it's been awhile since you posted this, but were you looking for a max/min of a feature set (scan, etc..) or between runs?Last edited by Sinned; 07-14-2008, 11:17 PM.sigpic
Scans, Perpendicularity, parallelism, ......................
Anything that would have a high and low range.
Seems like it would be an easy optional add on for Datapage to include.
Thankssigpic
PCDMIS 4.1, 3.5mr2,
Well then, my sugestion is to do what The Dude said. I if you do a textual analysis in PC-DMIS it will report it out for you, but not send it to Datapage. Here is some code that follows The Dude's suggestion, where x will equal your max, and y your min.
Code:PRO =FEAT/SCAN,LINEARCLOSE,SHOWHITS=NO,SHOWALLPARAMS=NO MEAS/SCAN BASICSCAN/LINE,SHOWHITS=NO,SHOWALLPARAMS=NO ENDSCAN ENDMEAS/ DIM PROFILE AX NOMINAL MEAS +TOL -TOL DEV OUTTOL M 0.0000 0.0029 0.0040 0.0020 0.0029 0.0000 -#------- PRO MAX/MIN=GENERIC/POINT,DEPENDENT,RECT,$ NOM/XYZ,PROFILE.MAX,PROFILE.MIN,0,$ MEAS/XYZ,0,0,0,$ NOM/IJK,0,0,1,$ MEAS/IJK,0,0,1 DIM MAX/MIN AX NOMINAL MEAS +TOL -TOL DEV OUTTOL X 0.0018 0.0000 0.0040 0.0020 -0.0018 0.0000 #-------- Y -0.0011 0.0000 0.0040 0.0020 0.0011 0.0000 ----#---- END OF DIMENSION MAX/MIN
by gszpotI have 30 pockets on a part that need width, length, parallelism,and perpendicularity checked on each pocket. However I only need to report the min and...
06-05-2020, 01:01 PM -
by gt143744Hi, I know it's been posted a tonne of times before but I can't make heads or tails of what's been posted. Please explain like I'm five. I need to report...
09-24-2020, 07:55 AM -
by hertangelHello,
how do you report MIN or MAX id that's what the drawing asking.
in other words the print calls for 25 max dimater.-
12-20-2011, 01:24 PM -
by rerun_livesCan anyone tell me how to send the max and min values from a dimensioned feature set to Data Page along with all my other report stats? ex. Max and Min...
04-04-2006, 06:05 PM -
by MikeFI ran a part with the min/max turned off, the customer wants the diameter min/max so I go back in the program turn on min/max output and they show min...
10-24-2018, 11:52 AM -
