I edited one of the variable info labels included with the software. I changed the =GetObjectName(FeatureVariableName) to =GetObjectName(DimensionVariableName) in one of the cells, saved to a different file name. I applied the newly saved label and it works as intended. I can then go back and edit the label and change something as simple as font size in one of the cells, reapply and receive a "label type does not match the source" error. Any ideas here? Getting a little frustrated.
Datapage 5.2 Editing Labels
That error occurs when you chose the wrong type of data source in your feature/dimension dropdown. You're trying to use features or dimension when you should be using feature variable or dimension variable. Or it could be reversed but not all labels can be applied to all data. I was able to take default labels and change fonts without issue as long as I applied them to the correct data type when creating a report.
If you're selecting "feature" then try to select "feature variable" or reverse. The same for "dimension" and "dimension variable".
Systems Integrator
I cannot reproduce any issue modifying fonts in custom labels and I tried to reproduce your issue just now. I would verify you're choosing the correct label for the data type and ensure that you select that label again when trying to reapply it. Datapage may just be choosing a different label type and deselecting the current label since there have been changes made to it.Systems Integrator
Well there is definitely something going on with my version of the software. I created a new label from scratch and it works perfect. However, if I open the label in editor and change anything I get the "label type does not match the source" error" after saving and reapplying. Before I though t maybe it had something to do with the fact that I was modifying one of the existing software labels. At this point I will just have to make sure that the label is exactly as I want it when I create it because it will no longer work if I open and edit.
by winstonnew to using datapage + (used the old DP about 10 years ago) in the cad tab i have imported my cad model and have 15 points of data XYZT dimensioned....
Channel: DataSuite SPC
12-27-2012, 01:20 PM -
by MIKEYI HAVE THIS WEIRD LABEL. actualy I am not sure what I did but at first I had this: CYL1 AND RIGHT NEXT TO IS CYL1(2) ON ALL OF MY LABELS. Then I hided...
02-14-2008, 01:48 PM -
by 57shrimpIs there a way I can show a group of ID labels say pnt20 to pnt50.
Or am I stuck with show/hide based on view or all ?
How can...-
12-15-2016, 05:43 PM -
How do I make the labels in the graphics view come back after I hide them?
09-03-2008, 04:22 PM -
by dmis100I been working with tech support on and off for the last week with this issue.This is the last thing I sent them.In the past versions when you went to...
04-19-2017, 09:17 AM -
