Exporting to datapage 5.2 from pcdmis 2018 R2
  • Exporting to datapage 5.2 from pcdmis 2018 R2
    We are upgrading from pcdmis 2014.1 to 2018 R2 and datapage+ 5.0(i believe) to datapage 5.2. The company I work for bought a global S green and it came with the new software. Since I have to re-establish all my prb files and re-work the programs to the new wrist. I figured we just get with the times now and upgrade the software as well. Now before, I would use an external command to throw my data from pcdemon to datapage. Do I just need to update that external command to read the new datapage software? Or is it more complicated than I thought it will be? How do I make this work?
    If I remember correctly. I had to update the path in each program. Technically there is Data Importer 5.0 and 5.2. If my path said 5.0 it wouldn't dump in 5.2, but would still dump in 5.0. When I updated my path to 5.2 then it would dump into both. This was my experience with this.
      Are we taking about the command:
      STATS/TRANSFER,DIRECTORY="YOUR DIRECTORY HERE"
      PcDmis 2015.1 SP10 CAD++
      Global 7-10-7 DC800S
        We use an external command also, and when we switched from 5.0 to 5.2 we had to change the path in every program that was using it.
          We also updated from Datapage + 2012 to version 5.2. Does the command: Stats/On,Datapage+,,Offline=Yes
          Record=All
          no longer work? We are running PcDmis 2017 R2
            No it's fine, works for me Midway
              Thank you for the reply. We were able to figure out what was going on. When we installed the new hard drive and fresh install of PC-Dmis the stats files were being placed in a different location from the old build.
                When you downloaded a fresh copy of Datapage I believe you have to set your path with DataPage and DataPage Importer.
                This is step by step setup with Pictures Midway
                https://www.pcdmisforum.com/forum/pc...ing-stats-over
                  Stats/on puts them in a directory specific to the version and there is no control of where it initially puts the file.
                  Systems Integrator
