DataPage export
  • DataPage export
    Forgive me if this has been asked before, but I can't locate it if it has.
    My company is getting a new CMM, but did not order DataPage for it.
    Can PC-Dmis export to datapage without having Datapage installed on that specific pc?
    For example, CMM2 exports results to datapage database, but is only viewable on CMM1
    which does have DataPage installed.
    Any help is greatly appreciated.
    Thanks!
    PC-DMIS 2013 CAD++
    B&S Global 7.10.7
    PH10M
    Point your DataImporter to a network location, Stats/Transfer from CMM to the same network location. Done. You have to use stats offline yes btw. Not an expert on DP but just recently played around with this subject it should work.
    PcDmis 2015.1 SP10 CAD++
    Global 7-10-7 DC800S
      Ok, sounds good. I hope it works out that way. New CMM is over a month out, so it will be a little bit before I can try it.
      PC-DMIS 2013 CAD++
      B&S Global 7.10.7
      PH10M
      • Kp61dude!
        Kp61dude! commented
        Play with your current setup...you'll have it all figured out before the new CMM arrives.
      Thanks!
      Yes, my DataPage computer is not connected to either of my CMMs. The database is local to the 3rd computer, and both CMM computers have DataImporter pointing to the 3rd computer. We use the DataPageStats.exe external command, so no Stats ON/OFF stuff.
      • SI_GUY_29
        SI_GUY_29 commented
        I have a question for you. We use external command as well to transfer the data to datapage. Now we first were transferring to datapage + 5.0 but we just got a new cmm and it cam with datapage+ 5.2. Do I just simply change the external command from 5.0 to 5.2? Or is there more to it to get the data to transfer?
      • VinniUSMC
        VinniUSMC commented
        I'm fairly certain that you don't even have to replace the DataImporter, but you might want to just to be safe. The data importer just puts the information into the database. So, install the new importer, make sure it points back to your database again, and you should be good to go.
        The database is SQL, so it's not specific to DataPage. You just need to make sure your new DataPage installation is reading your current database, and that should be all set too.
      I set this up all the time for our customers. Here's a tutorial video that shows how it's done: https://blog.cmmxyz.com/blog/pcdmis-stats-transfer
      CMMXYZ Applications Specialist: PC-DMIS Support and Training. Check out my PC-DMIS tutorial videos... https://blog.cmmxyz.com/blog/tag/cmm-tech-tips
      • Kp61dude!
        Kp61dude! commented
        Appreciate the content you all at CMMXYZ produce!
