Converting to as3 file
  • Converting to as3 file
    We are getting the following error when trying to convert IGES to AS3.
    Limits [340282346638528870400000000000000000000.0]
    We tried multiple files large and small with no success
    HELP!!!!!!!!!!!!!!!!
    You got this error when you use Dataview iges convert?
    How about creating AS3 from Pcdmis? while program open go to file, export, AS3.
    Let me know.
    sigpicIt's corona time!
      That option is available starting with Ver 3.25, the convert in Datapage sucks, and only works with wireframe.
      Jim Jewell
        Open up your iges file in wordpad... see attached... Where I have the two zero's highlighted, you need to add them. then where the line for my curser is located... backspace two times. Save the file and then try to import. Hope this helps more then confuse.
        Greg
