We have a part whose tolerance have changed. There probably isn't a way to "update" stats with the new tolerance is there? I could show a better Cpk on my parts if I could only change this tolerance.
Change in tolerance
Crap, I totally mis-stated what I was looking to do. It wasn't a tolerance change, it was a dimensional change. we had a depth change, and the new depth would bring all these parts into spec. I don't suppose it works for that too does it Matt?CMM Programmer
Jackson Michigan
Mistral 7.7.5
4.3MR2
Well, it will depend on WHAT axis you are reporting. If you are reporting an "M" (3-D distance or some such) OR XYZ axis, then YES, the nominal will update, then the measured should match. HOWEVER, if you are using T, it will not do you any good since the T is a deviation from a 3-D point in space (like for a vector point) and changing the NOMINAL of the vector point and getting a new T value and having it be good will NOT make the other T values in Datapage any good. The individual axis, yes, not a 'calculated' (for lack of a better word) axis based upon a single-point nominal. Do I have you confused yet?sigpic
by IronManSo I just completed a study on a part that has many holes called out as a zero tolerance but had LMC...
TP|DIA|0.0(L)|X|Y|Z|
Channel: DataSuite SPC
02-28-2011, 02:33 PM -
by BIGWIG7is there anyway to change the color of a feature if it measures out of tolerance?
for instance if i have a part with a bunch of circle features...-
05-01-2018, 05:17 PM -
by bfire85I don't have time to investigate this due to a rushed sort that is needed, but in the future, I would like to be able to accomplish this:
08-30-2021, 01:22 PM -
by T.DeCookDoes anyone have the formula to convert diametric to coordinate tolerance?
Thanks in advance!-
08-29-2007, 08:58 AM -
by DarrollhGood evening,
How would i go about setting a range for the tolerance? Please see the pic....-
09-01-2020, 12:43 AM -
