Is there a way to import data from excel into datapage? I thought I heard something once about being able to export and import data but now I can't find anything in the datapage help file.
importing
It is performed via the Editor. Database/Update. Measure Format would be SpreadSheet. A specific format is required. I will upload an example file. The name extention should be "txt". In the example file there are headings. Anything after MEASURED is considered a TRACE entry. Hope this helps.
One thing to remember is the Editor is a 16bit application. This means it cannot display long filenames or directories (it will use the ~ indicator). Think the golden, olden days of DOS (8.3 file name format).Attached Files
The data is going to a part name DEMO. You may already have this information in your database if you have not created a new one. You can edit the txt file and change the name to something else and import the data again. This time to a new part name. You can then either look at the data via the editor View/DataValues (I think) or via DataPage. Report/DataReport and select the part to display.
by truckinI have a study that is fairly small but unfortunately the part name needed to be changed and was changed last night so i need to know if/how i can move...
Channel: DataSuite SPC
03-19-2009, 07:58 PM -
by Perry FisherI've researched merging data from different Datapage databases into a common Datapage database. I've done it, I understand how it's done.
12-11-2008, 12:34 PM -
by rerun_livesI RAN 25 PCS. UNDER AN INCORRECT PART NUMBER. IS THERE A WAY TO CHANGE THE PART NUMBER IN THE DATAPAGE DATA BASE TO THE CORRECT NUMBER? CAN SOMEONE PLEASE...
07-11-2008, 11:42 AM -
by JOHNNIELEGAcan I merge a database with another version 3.3
same part # & features-
02-07-2014, 10:52 AM -
by oddamI am wondering if there is a way to adjust my export of data in a Excel file. When I export data, it seems to come out in text format with several decimals...
06-08-2015, 03:54 PM -
