As of yesterday at the end of a program where the results update into the Datapage database I get a error. ( Database System Error -127 Database files do not exist in selected directory.) I switched databases and same issue. I deleted my program and loaded a backup and same issue. I tried another program witch has ran for months and that program aslo has the same error. That told me its a datapage issue not my program. So I unlocked the databases and did all that and nothing worked. Then I uninstalled Datapage and reinstalled it. That did not work. Then I uninstalled, saved my database file in another folder reinstalled and created new databases. Still same issue. I dont know what else to do. Can anyone help. Also, at the end of the program when its generating the info to go to datapage in ususally will sat the name of the program and the specified database. But instead it gets stug generating and skips from database to database and even skips programs.
DATAPAGE 3.33 (Database System Error -127) HELP ME PLEASE...
As a side note, all 'good' data that has been sent to the XSTATS11.TMP file will still end up in Datapage, and when the good data is sent, it is removed from the file, however, any data with a database target location that does not exist, that will stay in there so you can open the file, fix the path, then update (from DPEditor) and recover the data. With all you've done, you are at the point where you can just delete the file. Deleting it does no harm since it will get re-created when you next send data to datapage.sigpic
Originally posted by Keren McComas View PostSo matt are you saying to delete the xstats11.tmp file, the whole thing?sigpic
in teh database directory, there are the following files:
VISTA.TAF and LOCKMGR.DBL.
You can either move them or delete them, then open Datapage and let it re-make those files.sigpic
by JJordanI just downloaded datapage v.3.33. I had version 3.32. The tech support said that it should write over top of 3.32 without any problems. I created...
10-13-2006, 12:03 PM -
by roddawgWhat causes the following database error:
"Error: Unable to access database for write operation"
It scrolls through...-
06-08-2006, 04:46 PM -
Our 2nd shift guy thought he was creating a database to put his stats in but only created the folder. He ran the program and nothing happened so he gave...
Channel: DataSuite SPC
01-11-2008, 04:01 PM -
by tinabeth
Hi. Thank you for your replys. I must be missing something because I still can't get pcdmis and datapage to work? So here is what I do step by step....
02-04-2009, 10:09 AM -
by Mike N.I would like to obtain a list of error codes generated by Datapage. Anyone got one?
One error i've seen is -8 or -16 I don't have a clue...-
05-22-2006, 10:49 AM -
