Results 1 to 5 of 5
Thread: Check Fixture Stab Pin Calculation?
      • 10+
      • 2011
      • Brown & Sharpe Xcel 9-12-9
      • Romulus Michigan
      • Quality / CMM Engineer
    ag162's Avatar
    Romulus Michigan
    463
    Default Check Fixture Stab Pin Calculation?
    I need one of our gurus out here to post their way of calculating the size of a stab pin on an attribute fixture. Using a .5mm hole with a tp of .1mm back to A, B, C with Max Mtrl cond and + .2mm - 0.0 size tol.
    Thanks in Advance,
    A.Gore
    A.Gore
      • 25 PLUS
      • 2010 MR3
      • HORIZONTAL STEF. AND DEA GAMMA
      • NORTH OF EIGHT MILE, ROSEVILLE MICHIGAN
      • CMM PROGRAMMER / LAYOUT TECH
    209
    Min hole size minus tp tol (0.5 - 0.1 = 0.4) , mmc would be on your location pins (b and c). The way we do it , our location pins would be adjustable for both ways (mmc and no bonus spring loaded step pins ).
    Was
    Pc-dmis 3.5 MR1 B & S 2009 MR1
    Now
    2010 MR3
    Guest
    1,279
    Nominal Hole Diameter - tolerence - TP.
    For a 5mm hole +/- .25 with a TP of 2, your stab pin would be 5-.25= 4.75mm then 4.75mm-2mm = 2.75mm stab pin size.
    For your pin it will be .5 - .1 and no lower size tolerence so your pin should be .4mm. Good luck making that one.
    Bill
    has received PC-DMIS total consciousness
      • V3.7 MR3 (have V3.2063 to V2012)
      • B&S Validator
      • He||
      • Inspector - Programmer - all around flunky
    Matthew D. Hoedeman's Avatar
    He||
    11,759
    Stab pin for a MMC hole is equal to the MINIMUM diameter of the hole minus the TP.
    Quote Originally Posted by AndersI View Post
    I've got one from September 2006 (bug ticket) which has finally been fixed in 2013.
      • 10+
      • 2011
      • Romulus Michigan
    ag162's Avatar
    Romulus Michigan
    463
    LMFAO!!!! It was for example use only............
    A.Gore
  1. Tooling Spheres.
    By AuRules in forum PC-DMIS for CMMs
    Last Post: 01-10-2008, 10:42 AM
  2. True position question when dealing with fixtures.
    By Jeff Hunt in forum PC-DMIS for CMMs
    Last Post: 12-04-2006, 10:19 AM
  3. checking a fixture using part CAD
    By Jonathan S in forum PC-DMIS for CMMs
    Last Post: 08-22-2006, 11:30 AM
  4. Checking a gage
    By cmmmike in forum PC-DMIS for CMMs
    Last Post: 03-11-2006, 03:53 PM
