Results 1 to 5 of 5
Thread: HASP - Failed to start the Aladdin Device Driver
    Nov 2007
    10
    Default HASP - Failed to start the Aladdin Device Driver
    I tried running Hinstall and received the error:
    Failed to start a service in the Service Control Manager Database
    I also downloaded the latest HASP drivers and it looked like it installed correctly - but then when I went to run PC DMIS it still could not locate the lock.
    This is a PC that recently had drive formatted and XP re-installed and upgrade to SP2. PCDmis and lock working fine on other PC which is same model, etc....
    Any Suggestions???
    Super Moderator Don Ruggieri's Avatar
    1,762
    What version of PC-DMIS?
    I believe that when XP came out, it was trouble for existing HASP drivers that worked fine in previous OS (2000, etc.). Are you sure the HASP driver you have is for XP?
    "You may be right, I may be crazy. . ." - Billy Joel
    Nov 2007
    10
    PC DMIS 3.24.... I ran the Hinstall that came with that... to no avail.
    then downloaded latest version from Aladin & ran - it appeared to install but then as soon as I tried to re-install pcdmis or run it - I still had the errors....?
    1,762
    Yes, 3.24 definitely has the wrong driver.
    As far as the driver from Aladdin, its generally a good practice to throw in a few reboots.
    Un install the old driver (hinstall -r)
    reboot
    install the new driver (hinstall -i)
    reboot
    Then try PC-DMIS install
    Nov 2007
    10
    It finally worked! I uninstalled driver - removed key - reboot. then shutdown, add key, startup and re-install driver - seems to work so far....
  1. offline pcdmis - hasp device
    By Joe Arnold in forum PC-DMIS for CMMs
    Last Post: 09-10-2007, 09:29 AM
  2. Math Failed Question
    By Durose in forum PC-DMIS for CMMs
    Last Post: 02-01-2007, 01:58 PM
  3. PCDMIS v4.1 - PDF Driver Issue
    By Underspec in forum PC-DMIS for CMMs
    Last Post: 08-19-2006, 09:17 PM
  4. Hasp Driver
    By John Kingston in forum PC-DMIS for CMMs
    Last Post: 07-11-2006, 12:34 PM
  5. What is a Hasp driver
    By Jeffrey Lovely in forum PC-DMIS for CMMs
    Last Post: 04-03-2006, 07:36 AM
