Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Romer vs Faro
      • 14
      • 2013MR1
      • BNS Global
      • CT
    Schrocknroll's Avatar
    CT
    383
    Default Romer vs Faro
    Any thoughts as to the benifits of Romer over Faro? My shop is thinking of getting a portable CMM and I'd like to get some imput as to which you think is better. Also do you have any suggestions in gereral for what to be careful about with portable CMMs?
    2013MR1
    Jeff
      • 10
      • 3.7
      • B&S, Faro, Sheffield,
      • Lexington, KY
      • Quality Engineer / Metrology Tech.
    russ.griffith's Avatar
    Lexington, KY
    43
    The Faro Arm is pretty good, We got one about 2 years ago. My biggest fault with the Cam 2 software is that it doesn't have feature recognition. Other than that it is pretty user friendly. We have only had one issue with ours, the encoder went out on one of the axis', they turnaround time for repair was about 2 weeks. There are 2 other companies in this area that we do work for and both of them have had trouble with encoders going bad. As for the Romer, I played around with an old one at a customers place once but to compare it to the newer model Faro wouldn't be comparing apples to apples.
    If the need arose for another portable I would definetly look at Faro again, but wouldn't limit myself to that choice.
    I might not love my job, but I love the ones it feeds!
    We have/been using a Faro arm (Silver)with PcDmis and have found it very useful out on the shop floor for jigs, dies etc.Was purchased about 4 years ago and doesn't have the Infinite Rotation that the Romer has now.
    Coot
      • Since 1998
      • Latest and greatest
      • Brown and Sharpe
      • Ontario
      • Technical Support
    Stuart's Avatar
    Ontario
    144
    Version 4.0 of PC-DMIS has made a nice interface and new algorithms for use with manual arms. Been training and supporting on the Romer for a while, a very nice product. Wireless is awesome. Also remember, you can by Romer and PC-DMIS from the same company, and get equally supported by both.
      • 19+
      • 3.7 and 4.0 Beta Tester
      • B & S Excel 152010 UHA
      • Danville,Il
      • CMM System Administrator
    Danville,Il
    7
    Thumbs up
    we recently bought a faro gage arm. as far as using it if it used in the way it was designed for it works great. if you are normally used to running PcDmis i would advise against the Faro software it is too limiting and the tech support we get fro Hexagon is 10 times better than at Faro. Just one programmers observation. i would also advise doing a correlation study between the arm and your normal cmm and see the difference it would have on using it in the manufacturing area. hope this helps Scott Bean
      • 14
      • 2013MR1
      • BNS Global
      • CT
    CT
    383
    Thanks for the replies. We did get the Faro. I haven't even had a chance to touch it yet, we're so busy right now. I would like to do a correlation between the Faro and one of our standard CMMs.
    2013MR1
    Jeff
      • 1.5 years
      • 3.7 MR2
      • Sheff Endeavor, B&S One
      • NY & Michigan
    NY & Michigan
    53
    Get to play around with it yet? Correlation study? Lemme know what you think about it, they're coming over for a demo in a couple weeks.
    Also Scott mentioned not going with the Faro software? What other software is there, and is one regarded substantially better? Anyone?
      • 14
      • 2013MR1
      • BNS Global
      • CT
    CT
    383
    I didn't get a chance to do the correlation study yet, but the other guy who is learning it checked a 1/2 inch gage ring and found it within a few tenths. I want to check some distances betwen holes or something like that. We are severly under staffed here.
    Coot mentioned that PC-DMIS will work with it.
    2013MR1
    Jeff
      • Since 1987
      • 2013 MR1, 2015.1
      • B&S Global, Mitutoyo w/PC-DMIS
      • LaGrange, GA
    Don Meredith's Avatar
    LaGrange, GA
    508
    We are using a FARO arm with Geomagic software (Studio & Qualify). We did a correlation of a scan to the same part run on the CMM - very close, <0.02mm.
    This may not be close enough for your parts, but since we make and measure raw sand castings, this is fine for us.
    v2013 MR1, v2015.1
    B&S Global 544, 555
    Mitutoyo A504 w/PC-DMIS
    Since 1994
    Never force anything. Get a bigger hammer.
    (Advice from my dad.)
      • 1.5 years
      • 3.7 MR2
      • Sheff Endeavor, B&amp;S One
      • NY &amp; Michigan
    NY & Michigan
    53
    Ya, with all the issues I already have with PC-DMIS though, I'm not too excited about getting it for a Farogage. Not to mention Hexagon is probably charging an arm and a leg for the software.
  1. PC-Dmis won't see Faro arm
    By Quality4you2 in forum PC-DMIS Portable
    Last Post: 12-22-2011, 09:10 AM
  2. Faro to DCC
    By thecoot in forum PC-DMIS for CMMs
    Last Post: 11-08-2007, 12:40 PM
  3. Faro Arm and PC-DMIS
    By John Riggins in forum PC-DMIS for CMMs
    Last Post: 07-27-2007, 08:21 AM
  4. 4.0,4.1 on faro?
    By mhesse in forum PC-DMIS Portable
    Last Post: 05-23-2007, 01:19 PM
  5. FARO help?
    By nicoletbn in forum PC-DMIS Portable
    Last Post: 10-13-2006, 08:55 PM
