Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Question about Leveling to a Primary Datum -A-
      • 8
      • 3.7 MR2
      • DEA Mistral
      • Vermont
      • Senior Metrologist
    Apr 2006
    Vermont
    74
    Default Question about Leveling to a Primary Datum -A-
    Hello everyone...
    We are currently having a discussion about leveling to a primary plane, (Datum A). The discussion concern is whether we should be leveling to a "high point plane" or if we should be leveling to a "best-fit" plane using every point that is probed.
    I am currently probing a planar surface that is approximately 150mm diametrically in 3 seperate rings that are 5 degrees apart so there are a total of 216 points. I have an overall flatness of approximately 0.3mm with a total tolerance of 0.8mm.
    As I stated before the disussion is whether we should be finding the high points of the plane and then be leveling to that plane or not (high point plane). I guess my feeling is that you would not level to the high point plane but in certain applications you may want to set the "Z" origin to that plane.
    What are your most common approaches of leveling to the primary Datum plane? Thanks for your replies!
    Mike
      • Since 1981
      • v3.7
      • B&S One
      • Central NC
      • CMM Software Programming & Training; Inspection Fixture Design & Build Measure Max programming and Training PCDMIS programming and Training CMM Automation. CMM Parametric programming. Programming for the shop floor is a specialty.
    cmmguy's Avatar
    Central NC
    3,351
    The high point plane is not repeatable. just like the max insc or min circ. diameters.
    Also, it would be difficult to set origin on a plane without leveling to it first.
    I think by definition the plane should be the high point plane but it is very difficult to achieve on a CMM and much less repeat.
    Most commonly used is best-fit. If you guys think that "high-point" is required then a datum simulator is needed.
    has received PC-DMIS total consciousness
      • V3.7 MR3 (have V3.2063 to V2012)
      • B&S Validator
      • He||
      • Inspector - Programmer - all around flunky
    Matthew D. Hoedeman's Avatar
    He||
    11,643
    Well, if you level to the 'high-points' of the plane, then you have just cut your tolerance zone in half, if it is bi-lateral, you are forcing all the 'non-plane' points to one side of your origin. Bad.
    Quote Originally Posted by AndersI View Post
    I've got one from September 2006 (bug ticket) which has finally been fixed in 2013.
    former user
      • 3.5
      • 3.7 MR3
      • Brown & Sharpe Xcel 7107
      • Cognito
      • QA Calibration Technician
    May 2006
    Cognito
    3,237
    It would certainly take an enourmous ammount of points to find the actual high points.
    I can see applications for both depending on the function of the part. I would say...
    I would think if datum targets are defined then use them. If no datum targets are specified, I would say average unless otherwise specified.
    I always do the average and have never had anyone ask about high points.
      • 8
      • 3.7 MR2
      • DEA Mistral
      • Vermont
    Apr 2006
    Vermont
    74
    I couldn't agree more cmmguy... Any more thoughts. I need to gather as much information as possible so that I can provide facts and logic to this conversation because these guys are talking in a theoretical world where every point would be analyzed and all that conceptual stuff. I'm dealing with a plastic part that is 6 inches in diameter and do not have the luxury of analyzing every point on the part nor could I do that in the first place.
      • 8
      • 3.7 MR2
      • DEA Mistral
      • Vermont
    Apr 2006
    Vermont
    74
    I think that so far all of us are on the same page here. The methods that you have mentioned are how I was "taught" orginally but my methods are being questioned so I need to explain why I do the things I do. Thanks a bunch for your replies I really appreciate it!!!
    Mike
      • Since 1981
      • v3.7
      • B&S One
      • Central NC
    cmmguy's Avatar
    Central NC
    3,351
    Quote Originally Posted by Matthew D. Hoedeman View Post
    The y14 (pg60) definition of the datum plane is exactly that - to the high points. It is just too difficult to achieve on a CMM. How are you cutting your tolerance in half?
    Apr 2006
    115
    What everyone else says -
    There's only one way to repeat the high point plane and that's if you use a fixture, probing the fixture to simulate the contact points which would be the highest points on the datum surface.
    If the surface stays within the form tolerance then it's probably good enough to level and assign as origin.
    PC-DMIS CAD++ 3.7 from 4.2 MR1
      • B&S Validator
      • He||
    He||
    11,643
    Quote Originally Posted by cmmguy View Post
    Everything has a tolerance. Everything. In sheet metal (and plastic too, I would imagine) every surface has a tolerance. I would imagine his print calls out a tolerance for that surface, either flatness or position or both. Now, do you want to shoot yourself in the foot by turning your 1mm tolerance band into 0.5 by choosing the highest points of the surface? If the surface is allowed (toleranced) to move 0.5mm in each direction, shouldn't you use the average plane to place both + and - points on the plane?
      • Since 1981
      • v3.7
      • B&S One
      • Central NC
    cmmguy's Avatar
    Central NC
    3,351
    Flatness is a moving band - so that doesnt apply
    Dont think position would apply either since it is the primary datum. Why would you apply anything beyond flatness to a primary datum anyway?
    So I still dont see where you are robbing yourself of any tolerance - sheetmetal, plastic, or machined parts.
  1. Slot as Primary datum
    By dwade in forum PC-DMIS for CMMs
    Last Post: 09-12-2007, 11:47 AM
  2. Another Datum Question
    By RussL in forum PC-DMIS for CMMs
    Last Post: 03-13-2007, 01:53 PM
  3. Datum Question
    Last Post: 03-13-2007, 10:01 AM
  4. Leveling 2 planes
    By cmmmike in forum PC-DMIS for CMMs
    Last Post: 08-15-2006, 07:59 AM
  5. Leveling a cylinder
    By RICHIE RICH in forum PC-DMIS for CMMs
    Last Post: 06-14-2006, 09:20 AM
