Results 1 to 10 of 12
Thread: OLE - Automation server cannot create object
      • (December, 2012) - Present
      • PC Dmis 2015
      • Brown & Sharpe PFX, Sheffield D8
      • Limbo
      • "I am the Quality. I am all there is."
    Rploughe's Avatar
    Aug 2013
    Limbo
    231
    Default OLE - Automation server cannot create object
    Hello all,
    I ran into this when trying to run a basic script to refresh my report window. This is the script i am using. Any ideas or suggestions to fix this?
    'Report Screen Refresh
    Sub Main()
    '************PC-DMIS declarations************
    Dim pcdApp As Object
    Set pcdApp = CreateObject("PCDLRN.Application")
    Dim pcdPart As Object
    Set pcdPart = pcdApp.ActivePartProgram
    Dim pcdReportWindow As Object
    Set pcdReportWindow = pcdPart.ReportWindow
    '***********Repaint the report window*********
    pcdReportWindow.RefreshReport
    '********************Cleanup**********************
    Set pcdReportWindow = Nothing
    Set pcdPart = Nothing
    Set pcdApp = Nothing
    End Sub
    Specific error is "error on Line 8 -OLE automation server cannot create object"
    Super Moderator Don Ruggieri's Avatar
    1,475
    is there a part program already open when you run this? Thinking about that, I suppose you could not run the script if the program were not already open.
    I just tried your script on my system with PC-DMIS 2011 and it worked fine here. Not sure what is going on.
    "You may be right, I may be crazy. . ." - Billy Joel
      • PC-DMIS CAD++ 2015.1 SP2
    4,223
    I assume you are running this on the computer that have PC-DMIS installed?
    It seems that the OLE object hasn't been properly registered as it can't create it?
    PC-DMIS CAD++ 2o15.1 SP3
      • 27 Years CMM Experience - ASQ Certified Quality Engineer
      • 3.2 thru 2013
      • 3 Brown and Sharpe PFX 4X5X4'S, 2 XCEL 7X10X7
      • Owner/President of; Quality Technologies CMM Labs Worldwide www.cmm9001.com or www.qualitytechnologies.com The Prosser Group - ISO/AS 9001 consulting
    Jun 2008
    141
    you probably need to register pcdmisutils.dll
    If not on you computer you can pm me for a copy
    32 bit systems use regsvr32 to install
    64 bit needs to be in "wow" directory under windows and admin priv's when in cmd to run regsvr32
      • PC Dmis 2015
      • Limbo
    Rploughe's Avatar
    Aug 2013
    Limbo
    231
    yes I am trying to run this on the machine Pc Dmis is currently installed on. yes there is a program running to call the script up to run. Pc dmis runs fine.
    I am running 4.3 MR1. My company just bought this machine from a 3rd party about 8 months ago. It sadly has been sitting unused for the last 7 months. I have been self teaching myself pc dmis, and learning its twerks.
    I also noticed that most activex applications don't run and error out as well. like pcd2xcel, datafieldedit, probe wizard etc. throws a "Runtime error '429', Activex component cannot create object."
      • 25+
      • 3.7mr3, 2012mr1, 2013mr1
      • 10 x DEA, 6 x B+S, 1 x Johannson
      • Lancashire, UK
      • programmer/dogsbody engineering dept advisor (gd+t) Drawing print translator I.T. weenie hater
    pwhitsa's Avatar
    Aug 2009
    Lancashire, UK
    1,544
    first off what o/s are you running pcdmis on?
    sounds like vpt is correct, the ole library doesn't exist or is incorrectly registered.
    you may need to reinstall pcdmis and/or reregister the ole automation library.
    if you are not setup as administrator then you need to be when installing pcdmis.
    Roses are red
    Violets are glorious
    Don't try to sneak up
    On Oscar Pistorius.
    MIL-TFP-41C
      • PC Dmis 2015
      • Limbo
    Rploughe's Avatar
    Aug 2013
    Limbo
    231
    its windows xp pro sp3. Unfortunately it looks like the machine came with 4.0 and 4.3 mr1. I assumed we were suppose to be running 4.3, you know the latest version installed on it. Looks like i might of been wrong. Everything runs fine in 4.0. Unfortunately I hate 4.0. With a passion. Thank you all for the help anyways.
      • 25+
      • Lancashire, UK
    pwhitsa's Avatar
    Aug 2009
    Lancashire, UK
    1,544
    Find out what the dongle is enabled for.
    Ditch 4.0 its the worst of the 4.* series by a long way.
    Even hex didn't put it on general release cos of the problems with it.
    Exactmeasure is a joke in 4.0.
    Roses are red
    On Oscar Pistorius.
    MIL-TFP-41C
      • 30+
      • 2014 SP4
      • Numerous bridge style
      • DFW area
      • CMM programmer
    DJAMS's Avatar
    Jul 2009
    DFW area
    939
    Quote Originally Posted by Rploughe View Post
    Try running version 4.3 as administrator.
      • PC Dmis 2015
      • Limbo
    Rploughe's Avatar
    Aug 2013
    Limbo
    231
    My IT guy won't even give me the option to do so. He gave me full access rights to it, which i tried to explain to him wasn't the same thing. I figured out that wilocx website no longer supports 4.3. The oldest version they support is 2009 release. My Dongle should be able to run 4.3. So for now i am stuck with the wonders of 4.0. As i highly doubt my company will shell out the cash for an upgrade or even be willing to look into the situation for me.
  1. Replies: 19
    Last Post: 11-15-2010, 01:33 AM
  2. Report Print Options Dialog Automation Object
    By jtwatmmi in forum PC-DMIS for CMMs
    Last Post: 11-02-2010, 02:36 AM
  3. AutoMation Object "Load Probe"
    By tj_max_011 in forum PC-DMIS for CMMs
    Last Post: 09-25-2007, 08:53 PM
  4. AutoMation Object Importing CadModel
    Last Post: 09-20-2007, 11:25 AM
  5. AutoMation Object
    Last Post: 09-17-2007, 12:10 PM
