Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: edit program
  1. #11
      • Since 2008
      • PC-DMIS CAD 4.3 CAD 4.3MR1 2014
      • DELTA DEA GANTRY
      • Ontario Canada
      • CMM PROGRAMMER/ QUALITY CONTROL TECH
    ADAM WALLACE's Avatar
    Jun 2009
    Ontario Canada
    1,234
    In this screenshot your edit window is open? In your previous post you said you only have graphic display window and report window open? Close all of these windows too make sure nothing is open in behind. Close them all edit window graphic window report window. Are you usind dual monitors?
    STANDING CORRECTED IS THE ONLY WAY I STAND
  2. #12
      • 18
      • Cad++ 2011 MR1
      • BnS/Global/Tesa+ShefDisc
      • oHIo
      • QA/Programmer/Operator
    krenginetics's Avatar
    Jun 2013
    oHIo
    63
    I am trying to see what all is going on there...my eyes aren't the best at this small resolution.
  3. #13
    Jun 2013
    21
    closed all windows and nothing is behind them. not using dual monitors and this is the ONLY program i am having the problem with. i went into older programs and added features just fine. DRIVING ME NUTS!
  4. #14
      • 9 yrs
      • 2013 CAD++
      • B&S Global Performance
      • San Antonio
    Wlayton's Avatar
    May 2012
    San Antonio
    80
    I know this doesn't sound right, however, have you tried to put an underscore in your spaces? When you name something like "manual z level", try "manual_z_level". PC DMIS is very mean when it reads and it may be reading your recalls as going back to manual mode. Just a suggestion.
    If there wasn't a wrong way, I would have no way at all.
  5. #15
    Jun 2013
    21
    SO.......I messed around in the program and when i started clicking throughout the program starting at the startup commands down through the program...IT WORKS. Very strange but up and running!
  6. #16
      • 1
      • 2010 MR3
      • B&S Global Performance 5.7.5, FX 9.15.8
      • Southern California
      • Take the blame...
    ClayT's Avatar
    Jun 2011
    Southern California
    478
    Quote Originally Posted by Cheryl View Post
    i'm at the end of the program and its active and then as soon as i click on the measure icon it goes inactive....and the only windows open are the graphic window and report window?
    [WAG] Maybe the window is opening somewhere off screen? Anyone using dual monitors there?
    edit: never mind... you already solved it.
    One screenshot is worth a thousand Need more info
    Never attribute to malice that which is adequately explained by stupidity...
  7. #17
      • 1985......2013
      • 3.206 updated by forward thinking mangement 7 weeks before retirement to Pc Dmis 2012
      • Finished on a baby Mistral .7.7.5
      • UK, East Midlands, Home of RR
      • Cmm Programmer...retired after 48 years @ the pointy end
    Oct 2008
    610
    Code:
    dcc top of v-block pln2=feat/plane,cartesian,triangle
    theo/<-0.9873,-3.5007,-0.7444>,<-0.0002937,0.0000302,1>
    actl/<-0.9872,-3.5006,-0.7428>,<-0.0028784,-0.0011952,0.9999951>
    meas/plane,4
    hit/basic,normal,<0.4191,0.0578,-0.7441>,<-0.0002937,0.0000302,1>,<0.4191,0.0579,-0.7304>,use theo=yes
    hit/basic,normal,<0.4138,-6.9496,-0.7439>,<-0.0002937,0.0000302,1>,<0.4139,-6.9494,-0.747>,use theo=yes
    move/point,normal,<0.4136,-6.9495,0.0286>
    move/point,normal,<-2.3938,-6.9475,-0.0233>
    hit/basic,normal,<-2.3935,-6.9475,-0.7447>,<-0.0002937,0.0000302,1>,<-2.3933,-6.9473,-0.7467>,use theo=yes
    hit/basic,normal,<-2.3884,-0.1636,-0.7449>,<-0.0002937,0.0000302,1>,<-2.3883,-0.1636,-0.7471>,use theo=yes
    move/point,normal,<-2.3886,-0.1646,0.3568>
    endmeas/
    v-block pln2=feat/plane,cartesian,triangle,no
    theo/<-0.9873,-3.5007,-0.7444>,<0.0002937,-0.0000302,-1>
    actl/<-0.9872,-3.5006,-0.7428>,<0.0028784,0.0011952,-0.9999951>
    constr/plane,rev,dcc top of v-block pln2
    datdef/feature=v-block pln2,a
    The use of mathmatical symbols in your headings is confusing for Pc Dmis...its been covered in numerous postings.
    Essentially what you are instructing the code to do is 'v minus block' & on more than one occasion.
    I would not even run a Cmm program with only 0.02 Hit & Retract values. Far too little time for dissipating any 'inertia' built up.
    In an 'O' ring groove would be an exception with speed adjusted to compensate of course.
    Poleaxe
    Beware the environment you live in for it will shape you
    Be careful the friends you choose for you will become like them.
  1. Edit window goes blank while running program.
    By Erikir in forum PC-DMIS for CMMs
    Last Post: 05-24-2013, 04:08 PM
  2. Replies: 11
    Last Post: 05-01-2009, 11:52 AM
  3. edit window/edit
    By tinabeth in forum PC-DMIS for CMMs
    Last Post: 03-26-2009, 03:22 PM
  4. Program Edit problem.
    By Hooch in forum PC-DMIS for CMMs
    Last Post: 01-29-2008, 11:31 PM
  5. Program edit?
    Last Post: 01-29-2008, 03:10 PM
