Results 1 to 5 of 5
Thread: Creating an alignment using datum targets
    Nov 2012
    5
    Default Creating an alignment using datum targets
    Hello everyone,
    I'm trying to create an alignment using Datum target points. I have never had to create an alignment like this and could use some guidence. Datum A is a flat surface that runs the length of the part, Datum B is four datum target points at varying heights along a curved surface, and datum C is a single target point. I'm currently using PC-DMIS 2011 MR1 on a fairly large B&S global. Any help would be greatly appreciated
    Thanks
      • 25 yrs
      • 3.7 MR4 / 4.2 (import only)
      • DEA/GLOBAL
      • Anderson Island, WA
      • Lead CMM Programmer/Contract Programmer
    John Riggins's Avatar
    Anderson Island, WA
    2,908
    This is what iterative alignments are for.
    Start by reading and learning what you can about those and then come back and ask more.
    It would also be a good idea to post a portion of the drawing or a screenshot of the CAD image.
    Sometimes the lights all shining on me...
    Other times I can barely see.
    3.7 MR4(step patch) CAD++
    PC-DMIS Ultra Guru
      • PC-DMIS CAD++ 2015.1 SP2
    5,189
    Quote Originally Posted by John Riggins View Post
    +1
    PC-DMIS CAD++ 2o15.1 SP2
    Nov 2012
    5
    Here's what the cad looks like. The 4 points shown are the datum targets. The ones that run the length of the part are B1,B2, and B3. The 4th target I can't reach with out moving the part( part is to long for my table). The point that is located on the rib is C1. Datum A is the whole bottom of the part. I started reading up on iterative alignments as you suggested, created one and added a scan of a profile I need to measure, it showed the scan way off the part and shows it measured like 5inchs. Not sure what I'm doing wrong
    Attached Files Attached Files
      • 12, but I am just getting back into it after an 8 year absence!
      • PC dmis cad ++2011
      • Sheffield Endeavor 12.30.10
      • Cross Plains TN
      • CMM Programmer <*)))><
    Oct 2012
    Cross Plains TN
    75
    http://www.pcdmisforum.com/showthrea...ly-plagarised)
    Here is a good thread to read on iterative alignment.
  1. Datum targets
    By Ralph Barrier in forum PC-DMIS for CMMs
    Last Post: 03-16-2010, 01:26 PM
  2. datum targets on different planes
    By here we go again in forum PC-DMIS for CMMs
    Last Post: 02-02-2010, 08:34 AM
  3. Datum targets again
    By Bob Pierce in forum PC-DMIS for CMMs
    Last Post: 09-25-2008, 10:53 AM
  4. non-coplaner datum targets
    By doo_hicky in forum PC-DMIS for CMMs
    Last Post: 03-20-2008, 06:53 PM
  5. Datum Targets
    By phil george in forum PC-DMIS for CMMs
    Last Post: 12-13-2006, 07:22 AM
