Results 1 to 10 of 12
Thread: Company logo
      • 3
      • 2011 MR2
      • pc dmis one
      • los Angeles, CA.
      • quality, manufacturing inspector
    em748's Avatar
    Apr 2012
    los Angeles, CA.
    24
    Default Company logo
    I tried to follow up the help menu (F1) to insert the company logo on CMM reports, with no success !
    is there anyone to help me with this ? PC-DMIS CAD 2011 MR1
    Best regards.
      • 2
      • pcdmis 2011 mr1
      • brown and sharpe
      • Da UP, eh?
    May 2011
    Da UP, eh?
    184
    FILE - REPORTING - NEW or EDIT- choose report templete you want to edit or create new report template
    ADD IMAGE TO TEMPLATE (cactus button), SELECT REGION - THEN load in the image with prompts in new window
    SAVE REPORT TEMPLATE
    OPEN REPORT WINDOW
    OPEN "TEMPLATE SELECTION DIALOG" - arrow with blue circle button
    ADD TEMPLATE TO LIST
    SET AS DEFAULT IF YOU WANT
      • 25+
      • 3.7mr3, 2012mr1, 2013mr1
      • 10 x DEA, 6 x B+S, 1 x Johannson
      • Lancashire, UK
      • programmer/dogsbody engineering dept advisor (gd+t) Drawing print translator I.T. weenie hater
    pwhitsa's Avatar
    Aug 2009
    Lancashire, UK
    1,556
    or just move the wai.bmp to a different folder and rename your logo as wai.bmp
    Roses are red
    Violets are glorious
    Don't try to sneak up
    On Oscar Pistorius.
    MIL-TFP-41C
      • several months
      • 2014.1
      • Advantage 7-10-7
      • eastern Pacific ocean
      • scapegoat
    sealevel's Avatar
    Aug 2008
    1,986
    *frustration avoidance tip*
    before editing your report template, go to the reporting directory of your PC-DMIS install, and make sure to remove the 'read-only' attribute from all the contents. (set to read-only by default)
    otherwise, your edits won't 'stick'.
      • 23
      • V2014.1
      • Brown & Sharpe Global & LK G90C
      • Fraser, MI
      • Director of Quality
    mdobb829's Avatar
    Jun 2007
    Fraser, MI
    288
    With your Program open, click on FILE at the top, and scroll down to REPORTING. Click on EDIT in the pop-up window to the right, and then click on LABEL TEMPLATE in the next pop-up window to the right. Open up the FILE_HEADER.lbl file. Left click on the header and then left click again on the logo. Once the logo is highlighted, right click on the logo. A box will pop-up that will allow you to browse for you company’s logo and insert it into the header. Your company’s logo will need to be saved as a .jpg, .bmp or .gif.
    Marty Dobson
    Director of Quality
    http://www.linkedin.com/in/mjdobson
    PC-DMIS CAD V4.2 MR1 & V2011
    PH10MQ
    TP200
    PC-DMIS Ultra Guru
      • PC-DMIS CAD++ 2015.1 SP2
    5,187
    Quote Originally Posted by mdobb829 View Post
    +1
    PC-DMIS CAD++ 2o15.1 SP2
      • 3
      • 2011 MR2
      • pc dmis one
      • los Angeles, CA.
    em748's Avatar
    Apr 2012
    los Angeles, CA.
    24
    Thank you very much .
      • 3
      • 2011 MR2
      • pc dmis one
      • los Angeles, CA.
    em748's Avatar
    Apr 2012
    los Angeles, CA.
    24
    Very helpfull, thanks
      • 11
      • PC-DMIS 2015.1 / DATAPAGE + 2014
      • Global Advantage 09-15-08 TESASTAR SM 80
      • HMS
      • Quality Supervisor
    MOREPOWER2U's Avatar
    Jun 2011
    HMS
    43
    I am having the same issue. What is the solution?
    TESASTAR_SM-80
    One foot on the brake and one on the gas Yea! - Sammy Hagar
      • 12 ish
      • PC-Dmis 3.7 >>>> 2012MR1
      • Many
      • UK
      • Technical Manager
    NinjaBadger's Avatar
    May 2006
    UK
    2,566
    Quote Originally Posted by MOREPOWER2U View Post
    the solution's above your post!
    Automettech - Automated Metrology Technology
  1. Company Logo/Header?
    By David Wedel in forum PC-DMIS for CMMs
    Last Post: 08-07-2014, 02:52 PM
  2. Modify company logo
    By Mansukh in forum PC-DMIS for CMMs
    Last Post: 04-04-2013, 03:30 PM
  3. New Aviation company Coming to town
    By bw_bob in forum PC-DMIS Blade Inspection
    Last Post: 05-22-2008, 08:18 PM
  4. How does your company handle SPC of unilateral tolerances?
    By slesholdofthreep in forum DataSuite SPC
    Last Post: 04-17-2008, 03:29 PM
  5. Company Logo
    By JacobMag in forum PC-DMIS Vision
    Last Post: 02-16-2007, 04:02 AM
