Results 1 to 4 of 4
Thread: Hasp Drivers
    Jul 2012
    1
    Default Hasp Drivers
    I am trying to move PCdmis from an NT4 machine to an XP machine.
    PCdmis is version 3.0864, after reading thru many of the threads here, it seems I need the XP version of the hasp drivers.
    I have tried the Alladin download link but the file keeps coming in corrupt.
    Does anyone have a link to the XP hasp drivers?
    Thanks, in advance.
      • 30
      • PC-DMIS 2011
      • B & S Performance 12-22-10 & B & S Advantage 15-40-10 with TesaStar-M
      • Miramar, Ca. Just minutes from the border
      • Chief Programmer
    johnP's Avatar
    Oct 2008
    364
    I believe you have to get them from hexegon.
    I am fluent in three languages:
    English, Sarcasm & Profanity.
      • several months
      • 2014.1
      • Advantage 7-10-7
      • eastern Pacific ocean
      • scapegoat
    sealevel's Avatar
    Aug 2008
    1,980
    Safenet now owns this stuff. Their site pretty much sucks, and is disorganized as all get up, but try here:
    http://sentinelcustomer.safenet-inc....dID=8589943583
    scroll to the bottom to accept all the licensing bs, and a hasp4 driver setup zip file download box will come up. This hasp driver setup is Version 4.102.5.22 (January 2006)
    seems like it might work for you. Later releases are also available. You just gotta search a bit. good luck!
      • 25+
      • 3.7mr3, 2012mr1, 2013mr1
      • 10 x DEA, 6 x B+S, 1 x Johannson
      • Lancashire, UK
      • programmer/dogsbody engineering dept advisor (gd+t) Drawing print translator I.T. weenie hater
    pwhitsa's Avatar
    Aug 2009
    Lancashire, UK
    1,556
    Quote Originally Posted by davidb247 View Post
    Thanks, in advance.
    The usb hasp drivers or the lpt hasp drivers?
    The usb hasp drivers are in the pcdmis install files for version 3.5 up.
    The lpt hasp drivers are hidden away somewhere on the wilcox ftp site.
    (because they want you to upgrade to a usb dongle)
    Roses are red
    Violets are glorious
    Don't try to sneak up
    On Oscar Pistorius.
    MIL-TFP-41C
  1. Mixed config - Hasp drivers not found
    By jcannon57 in forum PC-DMIS for CMMs
    Last Post: 01-21-2012, 06:21 AM
  2. Replies: 4
    Last Post: 12-21-2010, 02:37 PM
  3. HASP Device drivers??
    By DmisDave in forum PC-DMIS for CMMs
    Last Post: 02-09-2009, 07:43 AM
  4. HASP drivers won't install
    By METALMASTER in forum PC-DMIS for CMMs
    Last Post: 12-13-2007, 11:06 AM
  5. pdf drivers
    By wcdr99 in forum PC-DMIS for CMMs
    Last Post: 10-22-2007, 02:46 PM
