Results 1 to 10 of 10
Thread: Concentricity, how can I get a proper reading?
      • 1
      • 2011 MR1C
      • Romer Arm
      • Set Up Programmer
    BWood's Avatar
    Jun 2012
    7
    Default Concentricity, how can I get a proper reading?
    So, I am using a romer arm to measure concentricity of two holes. With a traditional CMM (and different software) we have found the concentricity of the holes to be 0.26mm. However, with the romer arm it shows the concentricity to be 2.9mm. If you take the acuals from the two holes and calculate the concentricity it should read like the traditional CMM???? Why is PC DMIS not giving me the correct reading? Any suggestions on how to measure this dimension with the Romer ARM?
      • since 1998
      • latest and greatest
      • Global Advantage 7-10-7
      • San Francisco, CA
      • Quality Lab Manager
    Wes Cisco's Avatar
    San Francisco, CA
    3,485
    Alien
    Quote Originally Posted by BWood View Post
    A nice fat Friday the 13th softball? Sure. . . I'll take a swing. . .
    Pc-Dmis does not calculate concentricity properly per ASMEY 14.5M 1994/2009. The only way to properly check concentricity per the standard requires the part to be rotated about the datum axis and two dial indicators applied to the surface of the feature being evaluated.
    But fear not! Most of the time when the concentricity symbol is placed on a drawing it is used incorrectly and what the designer is really trying to control is position.
    Pc-Dmis treats concentricity as if it were position.
    There are exactly 42,555,069 posts to date about concentricity on various CMM forums should you care to spend the rest of the day reading about exactly why CMMs can't "do" concentricity right, and elaborate possible ways to get sorta close with a CMM.
    HTH (Hope This Helps)
    "Hated by Many, Loved by Few" _ A.B. - Stone brewery
      • 30+
      • 2014 SP4
      • Numerous bridge style
      • DFW area
      • CMM programmer
    DJAMS's Avatar
    Jul 2009
    DFW area
    939
    Quote Originally Posted by Wes Cisco View Post
    Hey - this symbol shows 2 circles on the same centerline - that's exactly what I need! What's this called...... concentricity? I'm using that!
    Seriously though, you are right. It's a rare case where concentricity could not be replaced by position or runout.
      • 8
      • PCDMIS 2016 / Polyworks 2016, Reshaper, Solidworks, TubeShaper, DOCS
      • Stationary, Portable, Vision, Laser CMMs.
      • Dallas, TX
      • Hexagon Applications Engineer III
    Apr 2010
    Dallas, TX
    163
    I've seen a lot of falsely designed concentricities in my time. Make sure you're leveling correctly, or you risk the following:
    Click image for larger version.
      • 1
      • 2011 MR1C
      • Romer Arm
      • Set Up Programmer
    BWood's Avatar
    Jun 2012
    7
    Unfortunately, the call out is a true concentricity. S, I guess I will have to go to my management group and tell them that the $60,000 we spent on this equipment is not capable of a simple concentricity check
    In a couple of the 42 million posts, there is comment about using code to make up the check. Do you know how to make this happen?
    has received PC-DMIS total consciousness
      • V3.7 MR3 (have V3.2063 to V2012)
      • B&S Validator
      • He||
      • Inspector - Programmer - all around flunky
    Matthew D. Hoedeman's Avatar
    He||
    11,813
    Why not try CYLINDERS instead of just circles?
    As for the cost of the equipment.... that thing is a MANUAL machine. You must control it, it will not do it for you, and all it takes is a little slop on the part of the operator and all the data is bogus.
    Quote Originally Posted by AndersI View Post
    I've got one from September 2006 (bug ticket) which has finally been fixed in 2013.
      • 12
      • 2010 MR3, 2011MR1
      • DEA Scirocco 15-10-9, B&S Xcel 7-10-7, B&S PFX 7-6-5, Romer 3m Arm w/ laser
      • In a three day bender
      • Quality Engineer / CMM Programmer
    dccfreak's Avatar
    141
    Might be a dumb question, but are you selecting your features in the correct order? For example, the "datum" feature should be chosen second or PC-DMIS will calculate the results really funky. Also, if you're using an arm, have you made sure to set the proper probe comp by taking your first feature hit perpendicular to the surface? Not trying to be a wise guy, or doubt your skill, but I've seen these two factors come into play way too many times. Unless you're hammering the probe along your path, I would definitely excpect better results than those you reported.
    DCCFreak
      • 1
      • 2011 MR1C
      • Romer Arm
      • Set Up Programmer
    BWood's Avatar
    Jun 2012
    7
    I'll try selecting the datum feature secondly; however, from Wes's response, I thought I couldn't check concentricity with PC DMIS??? Thanks for the input. I understand the proper way to take the hits on the part. We just changed software from Power Inspect to PC DMIS and I am still working on the programming side of the software. Thanks.
      • Toolmaker 30+ yr / CMM 10+
      • cad++ 2011 / cad++ 2013
      • DEA Chameleon / B&S Global
      • Rah Cha Cha NY (Rochester NY)
      • Layout Inspection/Programmer
    dph51's Avatar
    Apr 2008
    2,726
    You can check concentricity with PCDMIS, BUT it reports it according to ISO standards. That is, it reports concentricity as TP (position).
    Lots of luck.
    B&S CHAMELEON/PCDMIS CAD++ V2011
    There are no bugs, only "UNDOCUMENTED ENHANCEMENTS!"
      • < 1 yrs
      • 2014.1
      • Romer Absolute Arm
      • California
      • FAI / CPK
    May 2015
    California
    15
    Quote Originally Posted by dph51 View Post
    Lots of luck.
    I have been reading a bunch of stuff and no one can explain this simply to me. I just want to know how to calculate this number. Basically anything I read says make sure it is centered. I don't want English I want math!! But your post is perfecT!! I can calculate true position [tp = sqrt(x^2+y^2)*2] with calipers on our car part. Thanks for also explaining it is ISO.
    Thank you
  1. Proper Way to Inspect Part per Concentricity Callout?
    By CarbideEVO in forum PC-DMIS for CMMs
    Last Post: 12-30-2011, 02:58 PM
  2. Proper Datum Set-up
    By sharney in forum PC-DMIS for CMMs
    Last Post: 10-07-2010, 02:14 PM
  3. Proper datum creation
    By DeWain Hodge in forum PC-DMIS for CMMs
    Last Post: 09-30-2010, 12:43 PM
  4. proper alignment question
    By j.gonzalez in forum PC-DMIS for CMMs
    Last Post: 04-03-2009, 02:49 AM
  5. proper way to dimension......
    By Mark Farren in forum PC-DMIS for CMMs
    Last Post: 08-29-2006, 05:28 PM
