Results 1 to 3 of 3
Thread: Minimum wall thickness
    Sep 2011
    1
    Default Minimum wall thickness
    Hi, I am trying to measure the minimum wall thickness for a small tube. The tube has three inner holes (kind of like ) and I need to find the minimum wall thickness for each of these holes to the outer OD wall of the tube. What is the best way to do this?
    Thanks,
    Becky
      • Since 2000
      • V3.2063 & 2010MR1
      • B&S Mistral 07-07-05 & Sheffield Discovery D8
      • Cleveland, Ohio
      • CMM Programmer, Auditor, Oversee Inspection Department functions, ASQ-CMI, CQT
    John Kingston's Avatar
    Cleveland, Ohio
    2,495
    1) Tube micrometers, can seam micrometers.
    2)Measure OD. Measure ID. Find difference between OD and ID. Divide by two. Repeat for each.
    The second method will only give you an average and won't help you find variation in thickness.
    EDIT: I didn't realize this was in the Vision section.
    There may well be a way of doing this, but I don't have a PC- DMIS Vision system.
    When in doubt, post code. A second set of eyes might see something you missed.
      • Since 1985
      • 3.5 - bleeding edge
      • Lots of them
      • Programming, support, (sales)
    AndersI's Avatar
    Aug 2007
    1,154
    You can create lines from the OD center through each of the ID:s, then create intersect points on the ID and the OD, and check the distance between the points.
    Click image for larger version.
    AndersI
    SW support - Hexagon Metrology Nordic AB
  1. Angle of a hole wall
    By 100thWideGlide in forum PC-DMIS for CMMs
    Last Post: 08-19-2014, 08:33 AM
  2. Fire wall blocking downloading efforts
    By Anthony Pritchard in forum PC-DMIS for CMMs
    Last Post: 11-25-2008, 03:06 PM
  3. Wall mounted Rack
    By Underspec in forum PC-DMIS for CMMs
    Last Post: 02-16-2007, 03:36 PM
  4. Checking wall thickness
    Last Post: 12-11-2006, 02:34 PM
  5. Wall Variation And Profile
    By jeremy kirk in forum PC-DMIS for CMMs
    Last Post: 11-23-2006, 09:00 AM
