Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: True Position of Square Slot on PC-DMIS VER.3.7
  1. #11
    has received PC-DMIS total consciousness
    • Additional Information
      • Years CMM Experience:
      • Since 1988
      • Software Version:
      • V3.7 MR3 (have V3.2063 to V4.2mr1)
      • Machine Type:
      • B&S Validator
      • He||
      • Job Function:
      • Inspector - Programmer - all around flunky
    Matthew D. Hoedeman's Avatar
    Join Date
    Feb 2006
    Location
    He||
    Posts
    10,686
    Default
    I really like how the two TP callouts for the same hole use the datums in a different order.
    Quote Originally Posted by AndersI View Post
    I've got one from September 2006 (bug ticket) which has finally been fixed in 2013. Admittedly a bit of a corner case for most users, but still...
  2. #12
    Ultra Senior Member
      • 18
      • Software Version:
      • 3.7mr3
      • Machine Type:
      • B&S Excel 7/10/7
      • London, Ontario
      • Job Function:
      • CMM Programmer/QA Technician
    Peter Warcholyk's Avatar
    Join Date
    Mar 2006
    Location
    London, Ontario
    Posts
    502
    Default
    Quote Originally Posted by Matthew D. Hoedeman View Post
    Perhaps there was a dyslexic engineer involved!
    You should one of the prints I just received. It can be quite interesting what they (engineers) come up with.
  3. #13
      • Since 1988
      • Software Version:
      • Machine Type:
      • B&S Validator
      • He||
      • Job Function:
    Join Date
    Feb 2006
    Location
    He||
    Posts
    10,686
    Default
    Quote Originally Posted by Peter Warcholyk View Post
    No thank you, I have enough engineer stupidity to deal with on my own!
  4. #14
      • Since 1988
      • Software Version:
      • Machine Type:
      • B&S Validator
      • He||
      • Job Function:
    Join Date
    Feb 2006
    Location
    He||
    Posts
    10,686
    Default
    For example, one I am dealing with right now.....
    Imagine a flat, rectangular piece of sheet metal.... (just so you can get the impression). Now, image a flange on the 'rear', that is only 1/3 the width of the part, and it is on the 'left', now imagine a flange on the 'front' of the part, that is 2/3 the width of the part, and it is on the 'right'. Now, put a TP tolerance with MMC on the gap, front-to-back, between them. These 2 flanges do not over-lap left-to-right anywhere, yet they want a TP-MMC of the gap.
    (see below, maybe it will help) Where the F=flange, N=no flange, B=base between the flanges. They want TP of the 'between'
    Code:
    FFFFNNNNNNNNN  /\ TP in this direction
    BBBBBBBBBBBBB  |
    BBBBBBBBBBBBB  |
    NNNNNFFFFFFFF  \/
  5. #15
      • Since 1988
      • Software Version:
      • Machine Type:
      • B&S Validator
      • He||
      • Job Function:
    Join Date
    Feb 2006
    Location
    He||
    Posts
    10,686
    Default
    Oh, and how about THIS callout (same print, and this is no joke!):
    Quote Originally Posted by stupid print
    FRIENDLY TRIM ZONE ALL EDGES
  6. #16
    Member
      • Since 2009
      • Software Version:
      • 4.3 MR2
      • Machine Type:
      • BS Global Advantage 5-7-5 PH10M TP200
      • Memphis, TN
      • Job Function:
      • Jack of all trades, Master of none.
    sly600rr's Avatar
    Join Date
    Sep 2008
    Location
    Memphis, TN
    Posts
    43
    Default More trickery
    After creating two mid points for both the x and y, could you not then create a generic feature using the xmidpoint.x for its X and ymidpoint.y for its Y and then do a True position on that generic feature?
    Or how about taking the average deviation from the width and height dimensions and using it for a generic circle size so you could do calculations for material condition modifiers?
    Or have I jumped too far out of the box?
    Yeah, But what have you done for me lately..?
Similar Threads
  1. True Position of a slot
    By csshaffer in forum PC-DMIS for CMMs
    Last Post: 05-24-2011, 12:34 AM
  2. true position of a slot
    By j.gonzalez in forum PC-DMIS for CMMs
    Last Post: 07-25-2009, 11:45 PM
  3. True Position - Slot
    By RSNICKER in forum PC-DMIS for CMMs
    Last Post: 06-03-2009, 10:40 AM
  4. Slot True position
    By Farmer in forum PC-DMIS for CMMs
    Last Post: 05-01-2007, 08:01 AM
  5. Slot true position
    By JamesMannes in forum PC-DMIS for CMMs
    Last Post: 05-22-2006, 03:19 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
