Results 1 to 10 of 10
Thread: Machine Error
      • 18
      • 3.7mr3
      • B&S Excel 7/10/7
      • London, Ontario
      • CMM Programmer/QA Technician
    Peter Warcholyk's Avatar
    London, Ontario
    501
    Sheffield Machine Error
    Attachment 6943
    Good Day Folks,
    Hopefully, I have actually attached the "attachement".
    This is an error that keeps on coming up. It occurrs when I am going from one movepoint to another If I am covering a "longer" distance, I will correspoindingly increase and decrease my move speeds.
    I am running a B&S 7/10/7 with pcdmis 3.7mr3.
    Just incase my attachement did not work the error in the "Execution Mode Options" box reads as follows; DOF; M54 invalid machine not in manual mode.
    This is during the execution of part programs, which are already in Dcc mode. When this comes up, I just click on "continue" and the program will run fine, until it decides to come up with the error again.
    I await the "Genius" of the great masters of pcdmis!!
    Many Thanks
      • 10+
      • Cad++v2009MR1
      • 737 Xcel
      • Chicago
    Roberto's Avatar
    Chicago
    2,165
    Can not see the error
    Too little.
    It's corona time!
    737 Xcel Cad++ v2009MR1....SE HABLA ESPAŅOL
      • 18
      • 3.7mr3
      • B&S Excel 7/10/7
      • London, Ontario
    London, Ontario
    501
    Sorry about the size.
    I did include the error comments within my message; "Just incase my attachement did not work the error in the "Execution Mode Options" box reads as follows; DOF; M54 invalid machine not in manual mode."
    Thanks!
    925
    Do you have more than 1 CMM?
      • 18
      • 3.7mr3
      • B&S Excel 7/10/7
      • London, Ontario
    London, Ontario
    501
    No, I'm only running the one cmm.
    925
    Can you post say ten lines above where the error is to ten lines below.
      • 10+
      • Cad++v2009MR1
      • 737 Xcel
      • Chicago
    Roberto's Avatar
    Chicago
    2,165
    Long probe maybe? Could be the TP2 or TP20 is going bad...Did you try a different module? Vibration in the machine?
    It's corona time!
      • 18
      • 3.7mr3
      • B&S Excel 7/10/7
      • London, Ontario
    London, Ontario
    501
    I had thought of your ideas as well. It occurrs with different TP2 units, and different lengths of probe styli. There does not seem to be vibration in the machine either.
    Thanks for the various suggestions so far.
      • 10+
      • Cad++v2009MR1
      • 737 Xcel
      • Chicago
    Roberto's Avatar
    Chicago
    2,165
    Hey Peter read this old post,
    Q: I just updated from 3.7 MR2 to 3.7 MR3 and I keep getting an error on the move point after a wrist change. The error is " DOF : M54 invalid machine not in manual mode". Just wondering if anyone else has had the same problem and if the knows a workaround.
    A: Turns out it was a bad interfac.dll file. Got with tech support and they said it was common with the downloaded file and Sharpe 32 controller.
    It's corona time!
      • 18
      • 3.7mr3
      • B&S Excel 7/10/7
      • London, Ontario
    London, Ontario
    501
    Roberto,
    Thanks for the update. I had originally starting searching for an answer in the older posts, but, had probably not gone back far enough. I'll try to take care of it tomorrow.
    Peter
  1. Machine Crash then Overspeed Error
    By Beth1471 in forum PC-DMIS for CMMs
    Last Post: 07-11-2011, 08:15 AM
  2. Machine Error
    By grandpaal56 in forum PC-DMIS for CMMs
    Last Post: 06-06-2008, 03:28 PM
  3. Machine error
    By TigerShark in forum PC-DMIS for CMMs
    Last Post: 06-06-2008, 03:21 PM
  4. Machine Error
    By PaulH129 in forum PC-DMIS for CMMs
    Last Post: 04-29-2008, 07:57 AM
  5. 3.7 MR3 machine error
    By R.Alward in forum PC-DMIS for CMMs
    Last Post: 05-24-2006, 08:20 AM
