Results 1 to 10 of 12
Thread: Setting alignment with compound datum
      • 2
      • PC DMIS 2010 MR2
      • Romer Infinite 2.0
      • SD
      • Quality Technician
    Jan 2011
    SD
    5
    Default Setting alignment with compound datum
    Hello everyone, I have a question that I'm hoping someone can answer. I have a print that is using a callout of A-D for the primary datum. Click image for larger version.
ID:	6832. Datum A is shown to be 2 mounting surfaces (Y vector) on the same plane. Datum D is being shown as a seperate mounting surface offset 13.9mm (Y vector) from Datum A. How do I go about leveling to both of these features? Have people that use Xactmeasure been able to get correct results using compound datums? This has been giving me a headache for awhile so I'm grateful to anyone who can push me in the right direction. We are using PC DMIS 2010 MR2 on a Romer arm. Thanks
      • 35 YEARS
      • 3.7 MR4 & 2009mr1
      • mistral,global image,global advantage & 1 off line seat.
      • PHX. AZ.
      • PROGRAMMER
    PHX. AZ.
    358
    Create a offset plane from a & d.use that in your setup.
      • 2
      • PC DMIS 2010 MR2
      • SD
    Jan 2011
    SD
    5
    So offset the Datum D plane 13.9 and then create a plane using the Datum A surfaces and the new offset plane? Then level to the new constructed plane?
      • 35 YEARS
      • 3.7 MR4 & 2009mr1
      • PHX. AZ.
      • PROGRAMMER
    PHX. AZ.
    358
    N0 measure 1 point on each surface then go to construct plane,click on the 3 points.In the bottom left hand corner you will see a box called offset plane.Open that and your 3 points will be there.2 of the points will be 0 offset & the 3rd. one you will set the offset @ 13.9 either + or minus depending if the 3rd. point is + or - from the other 2.
    PC-DMIS Ultra Guru
      • PC-DMIS CAD++ 2015.1 SP2
    5,180
    This *could* work:
    Measure datum A as a plane and define it as datum A.
    Measure datum D as a plane and define it as datum D.
    In the FCF builder (XactMeasure) type in A-D as primary datum and fill in the rest.
    I have read it in the helpfile, that this way of entering the compound datums should work.
    PC-DMIS CAD++ 2o15.1 SP2
      • 2
      • PC DMIS 2010 MR2
      • SD
    Jan 2011
    SD
    5
    Thanks for the replies. Can anyone confirm what vpt.se mentioned about measuring each datum and just entering A-D in the FCF builder?
      • several months
      • 2014.1
      • Advantage 7-10-7
      • eastern Pacific ocean
      • scapegoat
    sealevel's Avatar
    Aug 2008
    1,980
    i can't really see your dwg (eyes must be going bad) but i have attempted before to use what vpt.se said about a compound datum. only problem with my situation was that A-B (the particular datums in my case) were two planes A and B... a 'V' if you will....each banked 5 up off a theoretical plane of 0,0,1) Tried compound datum and it failed in Xactmeasure when using A-B.Sent the program to Hexagon and Tech Support (Quonset Point US) suggested to make a midplane from the two and construct a perp plane from that and use as the "A-B" plane in Xactmeas and it did indeed work.. (i needed Xactmeasure for my actual callout which was A-B|C|D for profiles with Unequal Tolerance Zones...unavailable in legacy)
    I don't know if this helps, and sorry for no images (it's friday nite and i'm having a few) but i would definitely try vpt.se's suggestion and wish you good luck!
      • 25+
      • 3.2063 CAD++ / 4.1RC (trash)
      • B&S Global 7107 (x2), Xcel765, Xcel9159
      • Muskegon, MI
    tking's Avatar
    Muskegon, MI
    1,534
    Offset plane is the way to go but you can use a jo block in a pinch
    TK
    Have a homebrew
      • 2
      • PC DMIS 2010 MR2
      • SD
    Jan 2011
    SD
    5
    So you're saying that I should measure the A datum then measure the D datum and offset the D datum the 13.9 mm? Then do I construct a plane from the A datum and the new offset D datum and level to the constructed plane?
      • 35 YEARS
      • 3.7 MR4 & 2009mr1
      • PHX. AZ.
      • PROGRAMMER
    PHX. AZ.
    358
    Read my post above!
  1. Compound Datum
    By IZAKK in forum PC-DMIS for CMMs
    Last Post: 04-13-2009, 09:50 AM
  2. Using a Cylinder as the A datum in an alignment..How?
    By TCeckels in forum PC-DMIS for CMMs
    Last Post: 02-18-2009, 10:34 PM
  3. Setting up a datum plane to recall
    By Paul Hewitson in forum PC-DMIS for CMMs
    Last Post: 05-13-2008, 10:29 AM
  4. Setting A datum
    By scharsch in forum PC-DMIS for CMMs
    Last Post: 01-31-2008, 12:03 PM
  5. alignment setting?
    By pcmac in forum PC-DMIS for CMMs
    Last Post: 09-27-2006, 12:49 PM
