Results 1 to 3 of 3
Thread: Error: An attempt was made to access an unnamed file past its end.
      • >3years
      • V4.3 MR1 (12/11/08)
      • Brown&Sharpe DEA, Scirocco-nt
      • Goshen Indiana
      • The Man!
    Aug 2006
    Goshen Indiana
    407
    Default Error: An attempt was made to access an unnamed file past its end.
    I was hoping someone could help me with this bug Ive got.
    The error message appears when I try to add a subroutine call statement to my "master" part program. After clicking on the select subroutine option dialog box, and then clicking on the external program which contains my feature subroutine. I get an error message as follows:
    "\<my program.prg>: Serialization error.
    Error: An attempt was made to access an unnamed file past its end."
    I've already tried deleting and recreating the probe file, but its doesnt seem to make any difference.
    The subroutine will run without errors if I execute it within the part program it is saved in.
    Im using PCDMIS v4.0
    Thanks
    Mr. Comment
    SCIROCCO-NT 13-20-10
    B3C-LC Controller (Leitz Protocol), SP600M, TP200
    PCDMIS CAD++ v4.3 MR1(Build: 12/11/08)
      • Some
      • V3.5 - latest and beyond
      • offline
      • Connecticut
      • Software
    Connecticut
    972
    I think there was a bug when you are trying to open the subroutine from this dialog. You can manually type the CALLSUB command in the edit window and fill in the information - you just cannot select the sub from the dialog. This has been corrected.
      • &gt;3years
      • Brown&amp;Sharpe DEA, Scirocco-nt
      • Goshen Indiana
      • The Man!
    Aug 2006
    Goshen Indiana
    407
    Fortunately this is my first experience with v4.0 and I noticed that other users are already using v4.1. I'm going to download that version and try again using the latest release then.
    Thanks
    Mr. Comment
  1. 4.1 permission access error
    By VONDY in forum PC-DMIS for CMMs
    Last Post: 06-12-2014, 05:21 PM
  2. Access error
    By Ken379128 in forum DataSuite SPC
    Last Post: 10-31-2007, 12:33 PM
  3. Running a program made on a dual arm cmm on a single arm?
    By Jeff Hunt in forum PC-DMIS for CMMs
    Last Post: 09-17-2007, 12:39 PM
  4. error--- past its end
    By Don Henger in forum PC-DMIS for CMMs
    Last Post: 12-13-2006, 07:08 AM
  5. How do you calibrate a custom made tip?
    By BSchwark in forum PC-DMIS for CMMs
    Last Post: 08-01-2006, 06:35 AM
