Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: ISSUE 1 v2011
      • Since 1996
      • v2012 CAD++
      • XCEL
      • DFW Area
      • Layout Inspection/CMM Programer
    DeWain Hodge's Avatar
    Apr 2007
    DFW Area
    856
    Default ISSUE 1 v2011
    I have a program that I have been using for a while in v2009. This program has three parts in a fixture that loops from part 1-3 moving Y 3.25" in every loop. I just upgraded to v2011 this weekend and now all the move points are messed up. Instead of moving to avoid the fixture it keeps moving and hitting the fixture. I stepped thru the program and all the move point are showing the correct coord. I went back to v2009 and used my back up and everything seems to be running fine. Anyone know whats up with move points in v2011?
    DeWain Hodge
      • 15+
      • 3.7, 4.1, 4.2, 4.3, 4.4 (2009), and 2010
      • Brown & Sharpe
      • Fort Wayne, IN
      • Quality Technical Specialist
    cmccullough's Avatar
    Apr 2008
    Fort Wayne, IN
    149
    What type of move command are you using MOVE/POINT or /INCREMENT??
    Brain- Pinky, are you pondering what I'm pondering?
    Pinky- I think so, but where will we find an open tattoo parlor at this time of night?
      • heard about this stuff this morning.
      • What is PC-DMIS?
      • machinist rule
      • Mamma Hoedeman's basement with Ironman, eating chips and playing cribbage, he cheats.
      • keepin your mom happy
    Ironhoe's Avatar
    Oct 2008
    1,849
    Ive seen the move/increment go completely to H3LL in the 2010/2011 versions after migration. No explanation. There is something evil lurking in 2010/2011 and I suspect it's partially in the tool kit, but I can't prove it out since my issues have been quite random.
      • 15+
      • Brown & Sharpe
      • Fort Wayne, IN
    Apr 2008
    Fort Wayne, IN
    149
    They had added more parameters to the move command. Thats why some users may have some migration issues.
      • Since 1996
      • v2012 CAD++
      • XCEL
      • DFW Area
    Apr 2007
    DFW Area
    856
    All I ever use are either move point or clearplanes.
    DeWain Hodge
    corelex's Avatar
    Jul 2009
    179
    <sigh> Oh, man... <sigh>
    Sorry, DeWain Hodge I am just sad I can not understand this at all. Programs from old versions should work, but not in PCDMIS. There is always something.
    Just now I have some other problems getting my program to work in 2009ver. Program ran and worked in 4.3 and not just offline like I think (this is just MO ) the Wilcox is doing the tests for PCDMIS.
    <sigh>
    still core to you
      • 15+
      • Brown &amp; Sharpe
      • Fort Wayne, IN
    Apr 2008
    Fort Wayne, IN
    149
    ClearPlanes you should be okay, but move point might be your issue. They have added a third parameter to move/point. It use to be MOVE/POINT,NORMAL,<XX.XXX,YY.YYY,ZZ.ZZZ> now its MOVE/POINT,NORMAL,[COORDSYS],<XX.XXX,YY.YYY,ZZ.ZZZ>
    [COORDSYS] can be PART or MACHINE.
    I mostly use ClearPlanes and MOVE/INCREMENT.
      • since1995
      • 2012 - Windows 7
      • GLOBAL 12-22-10 with 4th axis + One 775 + CMMV + LTD706
      • France
      • engineer
    Apr 2008
    France
    1,201
    Nice enhancement, thanks to had find it, cmccullough !
    Maybe there's a new parameter in the setting editor that give you a default choice between CMM and part ?
      • 4
      • v3.5, 4.3, 4.4
      • Sheffield Endeavor
      • Connecticut
      • Engineering Aid/Inspector
    Nov 2008
    Connecticut
    1,064
    When I encounter movepoints or features that do not move where they say they do- I export the program in Basic and look at all of the code/numbers there. You'll be able to pick out corrupt movepoints and other things.
      • 5
      • 2010 MR1/2011 MR1
      • Sheffield Apollo III RS-150/Sheffield Discovery II D-8
      • Blue Springs, MO
      • Inspector/CMM Programmer
    Sep 2007
    Blue Springs, MO
    58
    Quote Originally Posted by JEFMAN View Post
    Has anyone confirmed if there is a parameter that controls this in the settings editor? I use Move To.. commands almost exclusively. If it doesn't default to PART in the [COORDSYS] when the programs are migrated into 2011 I cannot see how we'd be able to move to 2011. We'd have way too many programs to fix to make it worth our while.
  1. Same issue...sorry
    By onehunglo in forum PC-DMIS for CMMs
    Last Post: 11-13-2009, 04:15 PM
  2. Run Issue
    By David Bazinet in forum PC-DMIS for CMMs
    Last Post: 10-28-2009, 09:17 AM
  3. 3.7 issue
    By Ravenmaniac in forum PC-DMIS for CMMs
    Last Post: 08-11-2009, 05:25 PM
  4. 4.2 Cad Issue
    By scman in forum PC-DMIS for CMMs
    Last Post: 06-12-2008, 01:01 PM
  5. Cad ID Issue....
    By drako28 in forum PC-DMIS for CMMs
    Last Post: 03-13-2007, 11:39 AM
