Results 1 to 6 of 6
Thread: Vectors
      • 11 years 5 w/ PCDMIS 9 w/MM4
      • 3.7MR3 & 2012 MR1
      • Global Advantage
      • Columbus Georgia
      • Quality Inspector
    AuRules's Avatar
    Dec 2006
    Columbus Georgia
    1,059
    Default Vectors
    Most of the programming I do is from the blueprint, but sometimes I use a catia model. In this latest project they are having me create a alignment using a plane and some bolt holes, easy enough. The problem is that theres a datum target on a 3d curved surfaces. I have the blue print numbers (X,Y,Z) but do not have the vectors. How can I get the vectors and use the blueprint numbers at the same time. The 1st attempt was to create the point, then go and use the mouse to touch on top of the point. But the numbers never match. Can someone please help a brother out.
      • 4
      • v3.5, 4.3, 4.4
      • Sheffield Endeavor
      • Connecticut
      • Engineering Aid/Inspector
    Nov 2008
    Connecticut
    1,213
    If you have a model in pc-dmis, create an auto vector point, plug in the XYZ nominals, and hit the little binoculars under the entry fields. This will look for the closest CAD surface and adjust XYZIJK accordingly. It will probably shift your nominal numbers more than acceptable. Reenter them, and hit the binoculars again. Keep doing this till you get only a few tenths of a thou error (maybe 2-4 times) on nominals and you are good to go.
      • 3.7MR3 & 2012 MR1
      • Global Advantage
      • Columbus Georgia
      • Quality Inspector
    AuRules's Avatar
    Dec 2006
    Columbus Georgia
    1,059
    donka----I think under my XYZ ia a find button
      • 25 yrs
      • 3.7 MR4 / 4.2 (import only)
      • DEA/GLOBAL
      • Anderson Island, WA
      • Lead CMM Programmer/Contract Programmer
    John Riggins's Avatar
    Anderson Island, WA
    2,912
    Find Vector....
    Sometimes the lights all shining on me...
    Other times I can barely see.
    3.7 MR4(step patch) CAD++
      • 3.7MR3 & 2012 MR1
      • Global Advantage
      • Columbus Georgia
      • Quality Inspector
    AuRules's Avatar
    Dec 2006
    Columbus Georgia
    1,059
    Hit find vector will give you the correct vectors off of the XYZ cordinate that I manually typed in? If so well holy smokes...Thanks
      • Small Customer CAD++
      • Endeavor 9.12.10
      • N. Hollywood, Ca.
      • Stir-up schit
    lambo's Avatar
    Mar 2008
    N. Hollywood, Ca.
    1,444
    Quote Originally Posted by AuRules View Post
    And also:
    SNAP=YES
  1. vectors
    By Ironhoe in forum PC-DMIS for CMMs
    Last Post: 10-07-2008, 06:20 PM
  2. The Joy of Vectors in 4.2
    By Ravenmaniac in forum PC-DMIS for CMMs
    Last Post: 09-08-2008, 10:33 AM
  3. Bad Vectors
    By Tested in forum PC-DMIS for CMMs
    Last Post: 09-20-2007, 07:27 AM
  4. Vectors
    By inspector212 in forum PC-DMIS for CMMs
    Last Post: 06-11-2007, 03:41 PM
  5. V4.2 Vectors
    By John Kugler in forum PC-DMIS for CMMs
    Last Post: 05-31-2007, 11:39 AM
