CPK fail on T Value
  • CPK fail on T Value
    I seem to be unable to get Datapage to calculate Cp or CPK on any T value. The PP is always 0.000 and the Ppk is negative...
    I suspect this is because my USL and LSL are the same, even though it's programmed in PcDmis as +/-. I can't change it in Datapage as far as I can tell, any ideas?
    ***Edit***
    The menua to change my USL and LSL was hidden, I had to check a box, show it, then put a "-" in from of my LSL, working fine now.
    You can change tolerances in DataPage on the DataEditor tab. Right click on the variable and select "Edit Variables".
    In PC-DMIS, are you using the option to "Show minus tolerances as negative" (or whatever the actual wording is). DataPage requires minus tolerances to have the "-" sign. And PC-DMIS may or may not, depending on your selection.
